Question about SINGER 7470 Sewing Machine
How to put thread inside sewing machine singer 7101.how to put t hread bottom side.
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Mimito7
  • 128 Answers
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Posted on Apr 19, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
  • 139 Answers
SOURCE: How do I thread a Singer 6104 sewing machine
http://www.singerco.com/resources/threading.html Check out their threading diagrams, they are really helpful!
Posted on Apr 05, 2010
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Singer 7101 not picking up thread
try changing the needle
rethread the machine top & bobbin
May 15, 2012 | Singer Sewing Machines
How do i thread the bobbin on my Singer Inspration?
there are threading diagrams on sewusa.com
singer.com has a free operation manual in pdf form to download
on the singer home page at the bottom look for operation manuals & click on it &
in the search box put the model number 4205,, the one on the bottom is free
Dec 11, 2010 | Singer Inspiration 4205 Mechanical Sewing...
I have a singer simple and within only seconds of sewing, the bottom thread will have bunched up 10 times of the amount of thread I would have thought I even used on the bottom side of the fabric
It is in your top threading. Rethread, and with the presser foot up, pull the top thread, it should feed smoothly, now put the presser foot down, the thread should barely move. This should seat the thread in the tension discs. Good luck
Dec 10, 2010 | Singer 3116 Simple
I do a few stitches and upper thread snaps. I feel I am threading it incorrectly and it is too tight
sewusa.com has threading diagrams
singer.com has free manual for a singer 1120
just go to the singer website & put in the box 1120,,the 2 bottom ones are free
Nov 30, 2010 | Singer 1120 Mechanical Sewing Machine
Bottom thread Ravel when sewing
take thread completely out. rethread, pull your foot lift up before threading. make sure thread is in the tension disk of you dial and notice if thread is a little tougher to pull when u put foot down...
May 27, 2010 | SINGER 7470 Sewing Machine
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
SINGER 7470 Sewing Machine Logo
385 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
