Question about Bosch Axxis WTL 5400 Dryer
Bosch wtl 5100 - spins but doesn't create a hot air flow.
  • Bosch Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Posted on Oct 02, 2010
My dryer working but not get hot conden water sign blinking what is this mean.
If dryer is not getting hot check the condition of the heating element(s).
Oct 10, 2015 | Bosch Dryers
Where is the reset button?
Most Bosch dryers have a heater reset button behind the main rear panel. If this thermostat has tripped, there is a REASON, resetting it may make things work for a short time but your issue is bound to return. There are many other things to check on Bosch dryers to ensure proper air flow throughout the dryer and house venting. Pleazer Appliance...
May 01, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Bosch WTL 5100 Tumble Drier rotates but does not heat
heatman101
Oct 22, 2010 | Bosch Dryers
My WTL 5410 dryer (electric condensation) has hot air coming out of the low rear duct opening (where the condentate hose connection is located. The hose is properly connected and occationally has water...
Welcome to FixYa.
You are correct, the unit being a condenser model doesn`t require any additional venting or exhaust to outdoors, that is the purpose of condensing the moisture internally.
As to the issue of air flowing out of the unit I`d suspect perhaps the heat exchange may need cleaning, if it is plugged it will cause the air to be directed elsewhere.
I`ve attempted to attach below the procedure for cleaning, if unsuccessful for whatever reason, too small for example, you or your landlord can email me at macmarkus@live.ca and I can send you the "pdf" guide for your Bosch dryer.
Keep me posted on your findings and I`ll try to assist you further if need be.
Thanks for choosing FixYa today and good luck.
Please take a moment to rate the info presented and leave a testimony if you feel it warranted.
Regards,
Macmarkus :)
Sep 28, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Dryer working well but thre is no hot air.
The heater element is probably burned out,but it's not a difficult fix. If you have a manual,it's pretty easy with basic tools
Mar 24, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
269 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
