Question about Lands Phones
Cannot call anyone
I have dial tone but when i dial a number i am told that the number is invalid. When people try and call us they get nothing.
  • 3 Answers
Have you tried the SIM card in another phone? If you haven't I would suggest that you try this. If the same thing happens in another phone to me that would suggest a problem with the SIM card and I would suggest that you contact your network provider to send out a new SIM card.
If the same thing doesn't happen then could be an issue with the phone. I would suggest then that you contact your phones manufacturer to see about a repair.
Posted on May 27, 2008
Can't dial out
bad phone or extension port try another working phone of the same type.
Aug 29, 2012 | NorStar M7324 Telephone
Call forwarding
Your options are...
Option 1: Hit 7 then 2 then #. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit 7 then 3 then #.
Option 2: Hit * then 7 then 2. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit * then 7 then 2.
Jan 29, 2010 | Nortel Norstar 16-Line PBX Speakerphone
My KX-T7030 phone will not send a tone during a call, so I cannot "Press 1" or any number to use automated options. It does dial numbers ok??
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Dec 09, 2009 | Panasonic KX-T7730 Corded Phone
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
Jul 26, 2008 | Uniden Cordless Phone
NO Dial Tone on Verifone tranz 380
It could be the number programmed to dial is invalid, or it needs a PABX (8 or 9, etc)
If you have digital lines, these terminals will function in an inconsistant way. Make sure you are using a dedicated analog line. If you have a fax machine, try that line.
You can try slowing down the speed by checking fields 542 and 543 and changing them from 2 to 1.
You're best bet is to call you terminal software provider.
Feb 07, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Lands Phones Logo
114 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
