Question about ECM Giotto Espresso Machine
ECM Giotto Premium (S/N 20030100413, purchased May 2003)
Turn on power switch and green on-light illuminates.
However, while lucite/plastic water reservoir is full, water pump does NOT run and after 20 minutes pressure remains at 0 and machine has not warmed up (neither sides nor steel tank are hot)..
Many thanks for all help,
Jerry DiBona
gerald-dibona@uiowa.edu
  • 1 more comment
  • Anonymous May 26, 2008
    actionmgr@yahoo.com
  • Olywagal May 29, 2008
    Same here... I have mine in the shop... no diagnosis yet. He did say it may have something to do with the auto-fill controller and that he has another one with a similar problem. Also commented that ECM has been sold, not dealing in the US very much now and that he's having trouble finding parts. Needless to say, I'm bummed... this was not a cheap machine. Olywagal
    Forgot to comment about one thing... green power light comes on, it doesn't not heat up and there is a 'clicking' sound that doesn't stop until it's either turned off or unplugged. - Olywagal
Fixing the water tank worked for me. Nice one!
Posted on Nov 19, 2008
Often the problem is the reservoir sensors think the water tank is empty. The metal rods that go into the white plastic tank are the sensors, and they contact the sides of the machine to provide an electrical ground. The water needs to be normal tap water, distilled water will not conduct...
At any rate, the fix is to simply jiggle the tank left to right to roughen up or clean the contact between the sensors and the body of the machine. Within a few minutes the machine should start to heat up, now that it knows you have water.
Hope that helps!
Posted on Jul 15, 2008
Well, I just spoke with the repair tech where I originally purchased my Giotto Premium 4 years ago. He knew exactly what the problem was when I described it... power light on, clicking noise (not remedied by a hard boot), water not coming out of the grouphead, not heating up etc. Apparently, this is a common problem, but is not the heating element; it's the relay box costing about $200 from GCM in Italy. Olywagal
Posted on May 30, 2008
I turn the ECM Giotto on, the light comes on but the pump does not activate and no heat. 2 hours later it all works fine.
Try this open the steam valve when you turn the machine on, leave the valve open until it starts to hiss with steam, then turn off valve. If that works then the vent valve is sticking and needs to be replaced.
Oct 12, 2011 | ECM Giotto Espresso Machine
ECM Giotto toggle (power) switch needs replacement ASAP in Seattle area.
i had this happen myself a few months ago, power switch blew, i took the machine apart took out the power switch, and visited a few local electrical component suppliers, its a standard switch but its 2 stage single throw switch, home depot/Lowe's don't carry this type. ended up going to 3 diff suppliers and finally found a commercial supplier that had it connected the new one and now its fine, works better than the old one ever did. just make sure you bring the broken switch with you when you go to show them, most good suppliers can match it and see if they have one like it in stock.
Apr 21, 2011 | ECM Giotto Espresso Machine
Reservoir tank is full. green light flashing(indicating low water)
There is a water level sensor at the bottom of the tank, probably is stuck. Examine it very carefully.
Feb 03, 2011 | ECM Giotto Espresso Machine
My Giotto Premium drops water from time to time - it runs out the holes in bottom of machine and makes quite a mass of water either side of machine on bench - we can't see a pattern - but do leave the...
Did you find a solution yet?
If your machine isn't plumbed in, so you have to fill the reservoir, I find it is easy to overfill, and the water runs out over the lip. I placed a fishing float with the long bit sticking up through the hole, so I can see when the water level is too low.
Dec 27, 2010 | ECM Giotto Espresso Machine
Help w/ ECM Giotto. pump doesn't turn on when pulling lever
Replace the magnets in the water tank, the reed switch is not reading one of them, most likely the safety or bottom magnet.
Feb 03, 2010 | ECM Giotto Espresso Machine
Ecm giotto repair
Jonny boy,,If you ever had a Macano box as a kid, tthe best man to fix the machine is you! Take many photos before opening the pipework. Clean out the scale and learn about your machine! No kidding, you brew a better coffee after that. You know ALL the functions after looking into the machine + ther are some ways to tweek it too. Steam press cam be set as well as water amount. I brwe a better espesso tha I get on town. Thick light brown crema. I gave upo with the dealer and hes so called repair people /// Olev
Aug 25, 2008 | ECM Giotto Espresso Machine
Giotto premium - is it a lemon?
My friend, had the same feeling,,,What have a done !! This piece of junk for all my dollars! No ,,it needs cleaning. Read all my comments re this. You can open this machine witha few fixed keys and mantain it. It will outlast you, when correctly mantained. All solid cupper and metal, no plastic. take it apart and CLEAN IT!
Remember - it is built by a human beeing. The ECM is a buty as it has very little automation built in. Very siple function = löong time in love with your machine. It is totally ANALOG = tweek it = better cogffee. /// Olev
Aug 23, 2008 | ECM Giotto Espresso Machine
Giotto Premium problem...
Try to do a hard reset by unplugging the device from the power outlet or take the batteries out and wait for sometime to reconnect.
May 29, 2008 | ECM Giotto Espresso Machine
Boiler fails to fill
your water container is not put it correctly. make sure both black plastic bars on the container are flush with the metal rails that they sit on.
Mar 01, 2008 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
576 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
