Question about Video Game Consoles & Games
Xbox 360 is flashing 3 red lights and doesnt play
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
Please click http://support.microsoft.com/kb/907534 to see about this problem.
As per the page:
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue: 1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Xbox 360: The power supply light is red 906102 (http://support.microsoft.com/kb/906102/) Xbox 360: The power supply light is orange 906103 (http://support.microsoft.com/kb/906103/) Xbox 360: The power supply light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again.If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support), and then click Console Repair? in the upper-right section of the Web page.
Hope this helps.
Posted on May 26, 2008
  • 10 Answers
SOURCE: As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Posted on Mar 15, 2008
SOURCE: fix xbox 360
the famous red ring of death caused by overheating stick a fan behind it!
Posted on Jul 15, 2008
  • 16 Answers
SOURCE: 2 red lights xbox 360
hardware problem... when it over heated it must of melted somthing in it... mine did that too
Posted on Apr 06, 2009
FixMyConsole
  • 174 Answers
SOURCE: i have one red light on my xbox 360 that is flashing
1 red light usually means a graphics chip problem. A reflow of the graphics processor usually solves this.
Give us a call / shout if you need any assistance.
FixMyConsole
Posted on May 25, 2009
  • 1093 Answers
SOURCE: XBOX 360 TWO RED LIGHTS FLASH
2 red lights is overheating and to get it fixed you will have to send it back to Microsoft and the waiting time is painful at 4 weeks, if you don't want to do this then you should fix it yourself using a good guide at home
Posted on Sep 21, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
How to fix four red flashing lights on xbox
Re check the connections of the cords, Specifically the AV. It might be as simple as a bad cord.
If that doesnt work, refer to this page, to determine the error codes you are having.
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Mar 16, 2010 | Microsoft Xbox 360 Console
2 red lights
Your xbox is overheating.
1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. 3. If the two lights continue to flash after trying the above steps, you'll need to contact Xbox Customer Support.
Jul 13, 2009 | Microsoft Xbox 360 Console
2 red flashing lights
The Xbox console is overheated.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
When i turn my xbox 360 on one light in the bottem right corner flash red and it reads E 74 error but when i unplug the xbox from the t.v it doesnt flash red, does this mean we need a new wire
one red light means the video card is dead not the cord and unfortunately cannot be fixed and to make it worse this error is not covered by warranty, if you want it under warranty tel microsoft wen you ring that it has 3 red flashing lights (RROD) not 1 as this error is covered by warranty
3 red lights on my x box 360
the dreaded red light...it happened because your xbox is on for long hours at a given time...give some rest and try again if red light goes green play for 3 hours let it cool down for 30 mins... if its dead then i'm sorry
Jan 13, 2009 | Microsoft Xbox 360 Console
FLASHING RED LIGHTS 1,2 AND 3
red ring of death
microsoft has a recal and repair for this failure, contact 1 888 4my xbox and begin the process, warranty has been extended for this fault only, many xboxes have been repaired more than once.
Jul 17, 2008 | Microsoft Xbox 360 Console
Flashing 3 red lights
The 3 flashing lights suggests that it's a hardware problem and you'll have to send your 360 to Microsoft for repair. Go on xbox.com and there is a link for repairs.
May 26, 2008 | Microsoft Xbox 360 Console
Xbox 360
Hi, I hope something from below is useful to you...
Sections 1, 2, 3, and 4 are flashing red
- The AV cable cannot be detected
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful in any way, please rate! Thanks
Nov 24, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
63 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
