Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 Memory Card Error
I just purchased a Nikon D40 and a Kodak SDHC 4GB card. The camera will not recognize the card. The book says this type of card is compatible but it reads on the screen no sd card inserted.
HELP!!
  • Anonymous Mar 16, 2009
    camera says card formatted but then immediately asks to reformat.  i'm stuck in a loop i can't get out of
    Problem Solver:
  • 6 Answers
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
Posted on Jun 06, 2008
Got s205 coolpix and experiencing problem whnever i put in the SD card.. it always says. card cannot be read.. card that im using is a new one and it is 4gb.. dunno if the problem is in the cam or the...
Actually a 4GB SDHC card should be compatible with an S205, as that camera is new enough to work with SDHC. One thing to try before going through the below linked troubleshooting tips is if you have another card, try it in the camera. If the camera recognizes it, then it's likely that the card you purchased was defective, thus you should return it.
For others reading with similar problems, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 26, 2011 | Nikon Cameras
New memory card dose not work. Keeps saying formatting. Its called SDHC memory card multi use.
Your problem is it's an SD"High Capacity" (SDHC). This type of card came out after camera was designed, and although it looks the same as a standard SD card, its not. Sorry, but there's no way to make that type of card work with your camera. But just go on Amazon, You can purchase a standard 2GB that will work with your camera for about $6 to $7 (total with shipping).
For others reading this with similar problems, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 25, 2011 | Kodak EasyShare Z760 Digital Camera
When i install team micro sdhc 4gb memory card in kodak easyshare z612 it says format .i select format but it keeps asking to format or cancell
First check make sure the SDHC card is unlocked I'll provide a diagram for that also I just checked your camera's memory capacity and it's only good for a 1 gig SD card which if using an SDHC memory card might go to 1.5 stretch to 2gig maybe but not a 4gig. My first impression is you got to much memory card for the camera. You might be able to go to the Kodak site and download updated firmware to allow the camera to function with the larger card but that's a maybe as well.
Here are the diagrams
And the memory capacity chart for your camera
Feb 02, 2011 | Kodak EasyShare Z612 Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Kodak 4GB SDHC Memory Card will work with Nikon D3100 camera
Yes. The D3100 will work with any SD card up to 2GB in size and any SDHC card up to 32GB in size.
Dec 18, 2010 | Nikon D3100 Digital Camera
Kodak easyshare M1093 refuses to format disk
The recommended card for your camera are those SDHC type or 2GB-16 GB SDHC card, try to use at least 2 SDHC card if this failed it means the memory card reader of your camera is already defective. Just in case this will happen try to contact Kodak at 1 800 235 6325 ext 12.
Feb 09, 2010 | Kodak EasyShare M1093 IS Digital Camera
Same as yours
The Z740 supports only MultiMediaCards & SD Memory Cards. 4GB and larger SD cards are usually SDHC (Secure Digital High Capacity) types - and bear the SDHC mark on the label. These cards are not compatible with this camera. Use only MMC and SD cards. SD cards are 2 GB and under - although *some* 4 GB cards are marked as SD too; these cards may or may not work. If you purchase a 4 GB SD (not SDHC) card, make sure that it can be returned if it doesn't work reliably in your camera.
Oct 05, 2009 | Kodak EasyShare Z740 Digital Camera
PURCHASE THE PNY 4GB MEMORY CARD
I have the same problem with the card, my cannon camera, and my gateway laptop. From what I've learned in the past ten minutes, the card is SDHC and my devices are not. The card is not able to dumb down and I am returning it to Best Buy. The HC in SDHC is the issue from my best guess. Similar to you cannot play PS3 games on PS2. I hope this helps anyone else.
Dec 07, 2008 | PNY 4GB Secure Digital High Capacity...
Will Sandisk yltra II 4gb card work with Nikon D40?
I assume you mean Sandisk Ultra..and the answer is Yes it will work fine.
A good choice card also..
Just beware that some computers will need the SDHC reader.
For example my SDHC cards can be read in XP without the reader but my Vista machines need the reader.
Good luck and happy shooting :-)
Nov 04, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
910 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
