Question about Invicta Reserve Subaqua Venom Swiss Quartz Sunray Dial Strap Watch for Men
How do I set my Invicta Subaqua Venom, got the watch as a gift and no manual.
  • 2501 Answers
SOURCE: How to set Invicta Reserve Men's Specialty Subaqua
You can get an instruction manual by going to their web site (www.invictawatch.com/), put your cursor over "collections" in the menu across the top and then clicking on "instruction manual".
Click on the "Invicta" logo and download the instructions.
Posted on Feb 14, 2010
escapement
  • 2334 Answers
SOURCE: How do you remove links from the subaqua venom
Find how to remove or add links here: Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
Posted on Apr 25, 2010
  • 3 Answers
SOURCE: How do you remove the links from an invicta
it's not much harder then normal push pins, just a little trick..push the pin out, doesn't matter which way. You will probably have to pull it out with pliers once you get it started.
once that pin is out, the band still won't come apart. There is another pin, a tube actually that the other pin went thru. it connects the center links. to remove it, you have to first remove the outer links. to do this you push them inwards, toward where your wrist would be if you were wearing it. (the links are actually two pieces-the center 'snake-skin' piece, and the outer bars. the outer bars are connected behind the center piece) the outer bars are what you push inward, they will pop out once the first pin is out.
Now you will just have the center piece connected to the adjacent center piece. That second pin (the tube) will just about fall out if you turn the band on its side. Now the bracelet will come apart.
To put back together, just line up the to center pieces, slide in the tube, then put the outer links in from behind the center piece (this actually locks the tube in place) then put in the long pin.
Ideally it will slide in halfway easily, then carefully tack it in fully. if it doesn't get in halfway jiggle the links and tap lightly. Don't use too much force until it's past 2/3 inserted or you will bend the pin.
Posted on Jun 11, 2010
mcdevito75
  • 1970 Answers
SOURCE: need a manual describing how to set the date for
mcdevito75 here, Best Bet, online to shopnbc.com to Invicta watches, or give Invicta a call , info at the website at ShpNBC.com
Posted on Jul 04, 2010
  • 12 Answers
SOURCE: I just received my invicta reserve subaqua
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
You must set the Reference time first (page 18).
Posted on Jul 15, 2010
How do I set the date on an Invicta Subaqua Noma watch
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Mar 06, 2015 | Invicta Watches
How to set date and day on INVICTA SUBAQUA NOMA III
Pull the stem out 2 clicks sets the time, pull the stem out just 1 click
turn it forward sets the day and turning the stem backwards sets the
date. I hope this helps
Jul 12, 2014 | Invicta Subaqua Noma Iii S
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
Feb 19, 2013 | Invicta Reserve Subaqua Venom Swiss Quartz...
I have an Invicta Venom #6111 with Poly strap. I want to put a Stainless steel ******** instead. How do I remove the caps covering the Screws holding the ********?
The caps are just for decoration. They dont cover anything. To remove the strap, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Reuse the pins with the stainless band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!
Oct 24, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
Hello, I hope that you can tell me some true info about this watch. It is the Invicta Subaqua Noma III (above). Watch descriptions say that the watch has a unidirectional rotating bezel. Is this true??...
<P>Thank you for contacting FixYa.</P><P>I dont know much about Invicta, however they have a wonderful website where you can download instructions or contact them.</P><P><A href="http://www.invictawatch.com/welcome/manuals/">http://www.invictawatch.com/welcome/manuals/</A></P><P>Best regards.</P>
Aug 27, 2010 | Invicta Subaqua Noma Iii Chronograph men...
Need a manual describing how to set the date for an Invicta Reserve Subaqua 6208
Jul 03, 2010 | Invicta Reserve Collection Subaqua Noma...
Apr 25, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
Invicta Reserve Subaqua Venom Swiss Quartz Sunray Dial Strap Watch for Men Logo
138 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
