My monitor screen keeps getting dark. No matter if I try and lighten it up, it doesn't work. Is it time for a new one, or can I do something?
  • 6,487 Answers
Base from the description of your problem the issue here is a failing monitor already and having it repair will may cost as much as new monitor so the best advice here is to have the monitor replace.
Posted on Oct 02, 2010
All pictures come out dark, no matter the light
What model K-M camera? What exposure mode(s) are you using?
Dec 04, 2013 | Konica Minolta Cameras
My lap top does not display anything when turn on
There might be a problem with your display. This might be 1 of several problems, which i will go threw in a moment. First of all, try to connect your laptop to a normal monitor with a cable, if it doesn't show anything at all, you are out of luck... but let's go threw the possibilities:
The flat (connector to the motherboard) is not properly connected or its damaged
  • In this case, the external monitor connected to your computer will work just fine, this is a minor problem, the cable is cheap it-self so, if your computer is still in warranty, take it to the support, they will fix it.
The liquid crystals on your monitor are damaged
  • Try lightly tapping the zone on the bottom of the monitor, does something happen? A computer monitor works by LEDs or Liquid Crystals, if they are damaged tapping the zone where the connectors are (typically the bottom and the top of the monitor) should make some color appear randomly. This is bad, the external monitor will work as well, but this a an expensive malfunction, if the computer is in warranty take it to the support, they will fix it, else, consider buying a new laptop, the monitor is almost the same price as the laptop itself most of the times.
Connected external monitor also black?
  • This mostly means your graphic card is damaged. If the laptop is in warranty, take it to support.
You can see something pretty faint and dark on the monitor?
  • This means one of 2 things. The back-light of your monitor is damaged. Recent laptop displays use a light to lighten the screen so you can see the monitor from every angle, if this light is damaged, the monitor will work but very dark... Try pointing a flashlight to the monitor, if you see something better, you have found your problem. Once again, warranty time, a back-light replacement is a bit costly...
  • Another, less problematic, issue is that if your computer receives an high voltage charge, it will automatically shutdown some circuits for safety the monitor is one of them. In this case, remove the battery, shutdown your pc and press the Power button for 30-60 seconds. This will make the computer discharge all current on the circuits. Let it rest for a minute or 2 and power it on again, if this was the problem it should be fixed now.
Hope this puts you on the way to find your problem. Good luck! :)
Jun 25, 2011 | Gateway Computers & Internet
To whom it may concern, The screen is very dark. How can I fix it? Also, how can I change the brightness? thank you for your time!
To adjust the screen contrast (to lighten screen or to darken it)
  1. Press the [2nd] key and RELEASE it.
  2. Press and HOLD the UP Arrow to darken screen, or
  3. Press and HOLD the DOWN Arrow to lighten it.
Keep pressing the UP or Down arrows (whichever you need to press) until the screen contrast is adequate.
In your case, the screen is too dark, so you must press the DOWN arrow to lighten it.
Aug 12, 2010 | Texas Instruments TI-83 Plus Calculator
450SX4 15" LCD SCREEN is too dark, can barely makeout
Use screen adjustment to lighten, if you have done that try it with another PC,
If that works either your vid card (If you have one) or the mobo drivers need updating.
Jan 26, 2010 | Gateway FPD1760 17" LCD Monitor
A90f dark dark screen
Use brighten controls on monitor to lighten
Dec 22, 2009 | ViewSonic A90f+ 19" CRT Monitor
Screen too dark
Try holding CTRL down and pressing F6 to lighten and F5 to darken screen...
Sep 11, 2009 | Acer AL2016WBbd Monitor
MONITOR VERY DARK
Try using the FN key and the up arrow at the same time while tapping the up arrow, also make sure that if you have vista, you are not in "power saver mode". if there is no light at all coming from your screen, you may have a bad display bulb, this could also be a faulty invertor, but you would have noticed a constant flicker.
Sep 07, 2009 | Gateway Computers & Internet
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
Too dark
This IS an inverter issue. You need a new inverter. Open the LCD and find the inverter model number and search Ebay.
-CharlyV
Dec 28, 2007 | CTX S762A 17" LCD Monitor
Screen too dark
Hi, This might also work for you, http://www.fixya.com/support/t162607-dim_compaq_s510_crt_colored_monitor However, this involves opening the monitor so not unless you're comfortable working with tools and open units, I would recommend that you ask the services of a qualified professional. Good luck and kind regards.
Jul 31, 2007 | Gateway EV 910 19" CRT Monitor
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
