Question about Jensen A300HLX Car Audio Amplifier
JENSON A 300HLX WIRING DIAGRAM NEEDED
I NEED THE WIRING DIAGRAM FOR THE 6 PIN HI LEVEL INPUTS. tHEY DONT SELL THE MANUAL ANY MORE OR HAVE PARTS FOR IT AND THE 6 PIN PLUG IS MISSING. i NEED TO HOOK THIS UP TO ME FACTORY SYSTEM
  • Anonymous Sep 04, 2008
    i NEED THE WIRING DIAGRAM FOR THE 6 PIN HI LEVEL INPUTS
  • active_zone Sep 04, 2008
2 Suggested Answers
  • 70 Answers
SOURCE: Jensen XA 2100 Amp. Need
the black wire is ground, white is + and white/black is - that's for the left side speakers and the gray is + and gray/black is - that's for the right side speakers and that hooks up to the speaker wires coming from radio to high level input plug if you need a diagram this is the website http://a248.e.akamai.net/pix.crutchfield.com/manuals/110/110xa2100.pdf and look on page 5 it will show you. please vote and leave high marks. Thank you and I hope i answered your question
Posted on Aug 03, 2010
kenw392
  • 2226 Answers
SOURCE: i want to add another amp to my system, my jenson
Yes you can. That should be no problem.
Posted on Oct 05, 2011
Need a wiring diagram for a bmw r90/6 motorcycle
Hi, Mike what you need is a wiring diagram that you can find in the back of your service manual if you can not find the first and best tool you ever bought for your bike, despair not, I have found one for you that costs ten dollars. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day. http://bmwmotorcycletech.info/R90S.pdf
http://r90sclub.dudley.nu/Articles/R90S+Wiring+Diagram.pdf
BMR R60 6 R75 6 R90 6 service Shop repair manual Download Manuals Technical
BMW Parts Microfische
BMW R60 6 Owner Manual
Nov 20, 2016 | BMW Motorcycles
2001 grand am se1 factory radio wiring
The person asking this question has a PONTIAC GRAND AM SE, NOT a Grand Prix. (Not the same car).If you will go to any local auto parts store they will carry the repair manual for your car. The repair manual has the wiring diagram for all the wiring in your car in the back part of the manual. It will be called the HAYNES Auto Repair Manual for the year of your Pontiac Grand Am SE. I just dont understand how some people can be so ignorant as to excessively cut wiring out of a car when they dont even know what they are doing. Go figure. lol. If there is a college or a trade school in your area that has courses for auto mechanics , most of them repair cars also. They usually do not charge a labor charge, they only charge for the parts needed to repair a car and also a small shop fee. If this is the case in your area give them a call asap. They can help you. I used to have a 2002 Pontiac grand Am SE 1. I now have a 2004 Pontiac Grand Am SE 1 and I am going to sell it. If you need any more help just respond back. Hope this helps.
Sep 16, 2014 | 2001 Pontiac Grand Am SE
Wiring diagram for yamaha ybr 125
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/9005-ybr125-2007-wiring-diagram-and-technical-really-technical-spec
Wiring diagram for yamaha ybr 125 Google Search
Yamaha YBR125ED 2005 Service Manual
OEM parts for Yamaha
Yamaha YBR125ED Owner Manual
Dec 21, 2012 | Yamaha Ybr 125 Motorcycles
I got a Raythoen ST1000 tiller pilot with my new yacht but its still in box without wiring or any other instructions. There is a six pole socket on the cable and I need to identify which is power and -...
Hi!
As you're looking at the tillerpiot receptacle from the back, rotate until the "keyway" on the front is located in the one o'clock position. Your 12v power supply (pin 1) will be slightly below 9 o'clock and your ground (pin 2) will be above pin 1.
Other pinouts designations:
Pin 3= not used
Pin 4= SeaTalk
Pin 5= NMEA -
Pin 6= NMEA +
Your owners manual can be found on the Raymarine website here:
http://www.raymarine.com/productdocumentfinder.aspx
Use the drop-down menus to select Autohelm 1000+
Hope this is helpful!
Sep 11, 2010 | Raymarine Boating
I need a wirind diagram for a jenson lx 400 watt-
You should not need a wire diagram, all amplifiers are universal. 2 sets of speaker inputs, power "Large Red", ground "Large Black", and remote off/on "Small Blue". Thanks
Jun 08, 2009 | Jensen LXA400 Car Audio Amplifier
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Nov 27, 2007 | Kenwood KSC-WD250 Car Subwoofer
Jensen A300HLX Car Audio Amplifier Logo
193 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
