I got this Sansung LN46A750 and when I try to turn it on the tv turns on and off for at least 5 minutes and then turns on. Sometimes I press the on and off myself to help it turn on. While this is going on I can not turn the tv off. Thank you, Thanasis
    Problem Solver:
  • 7 Answers
Poltergeist ! definitley. Probably possessing your remote control, stuck button, either there or on the tv itself. Take a q-tip with a little isopropyl alcohol and clean around control surfaces. Do the buttons spring back out when you push them in? Maybe its receiving signals from the great beyond,(your neighbors, kids, co-inhabitants). I once did a carpet job where this guy was channel surfing for at least an hour(continuous), it wasn't my place to say anything to the dude, but then I noticed he was sleeping on his remote control.
It could be a bad switch, with a thermal problem, (picture how a christmas tree bulb blinks on and off), interrogate the suspect with a hair dryer,(not too close, or too long, it will melt things) just see if
heat has any effect on the symptoms. And it's cheaper than the reverse process, the canned air treatment where you invert the can to get pure compressed liquid, and the resulting 70 below zero evaporation cooling. It's better for things that boot up fine, until they get warm, and then they shut down, the reverse of you symptoms, yes?
Posted on Oct 02, 2010
Tip
RCA Universal Remote Programming Instructions And Codes
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 to 6 again.
To Get The Code Please Go To Below Website:
http://remotefinder.rca.com/default.aspx?site=rca
You need to select the following informations from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
3.Make of the device(Philips,Sansung)
Thank you
on Jul 27, 2010 | Televison & Video
LN46A750 clicking sound wont turn on
I would start with having the power supply capacitors checked.
Nov 24, 2012 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
Turn on without remote control
If the TV was switched OFF by remote control for the last time, you can't switch it back ON, without its remote control.
Just try this. Unplug the TV from AC mains wall socket. Wait for at least 5 minutes and plug it back. Switch it ON by its front panel power ON/OFF switch. Just press any button [Ch UP / Ch DN or Vol UP / Vol DN] Sometimes this might turn ON your TV.
Jun 02, 2012 | Televison & Video
We own a Sony FWD-50PX2 television. A few weeks ago it would not turn on. The power is going to the television. When you try to turn the tv on you can hear it pop and the red light showing it is off...
this is a common issue i think. below steps solved this issue for an user.
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 23, 2017 | Sony FWD50PX2/S 50 in. Plasma Television
Tv turning on and off by itself - never fully turning on
Most likely failed capacitors in the power supply. I am currently having the same problem with my 26 month old LN46A750. Samsung has agreed to fix this as an out of warranty "courtesy repair".
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
http://www.avsforum.com/avs-vb/showthread.php?t=1198409
Sep 28, 2009 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
Pioneer SD-P6091 Projection TV - TV turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 20, 2009 | Pioneer SD-P6091K TV
DLP tv trouble shooting
Try and clean the filters or the plastic fan guards.
Jul 30, 2008 | Home Security
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
