Question about Mongoose 12v 10ah Scooter Battery Schwinn (set Of 2)
How do you hook up new batteries - Mongoose 12v 10ah Scooter Battery Schwinn (set Of 2)
    Genius:
  • Mongoose Master
  • 1,508 Answers
Negative from one battery to the vehicle and positive from the battery to the vehicle then connect the remaining two terminals of the two batteries together with one wire
Posted on Jun 29, 2012
I hooked anew battery up incorrectly. Now i have no power to starter, lights etc. I have checked fuse box and all are fine. Are there other fuses that arenot in the fuse box
Consequences of Hooking a Car Battery backwards - Car Talk
community.cartalk.com/.../consequences-of-hooking-a-car-battery-back...
Mar 4, 2010 - Hooking up the battery incorrectly blew the alternator. ... settings to operate best since it no longer matches the performance of a new engine.
hooked up battery wrong way - Car Forums and Automotive Chat ...
www.automotiveforums.com > ... > Chevrolet > Caprice
Feb 27, 2012 - hooked up battery wrong way Caprice Car Forums. ... also replaced the number 17 elec fuse with a new 15amp, hooked up battery right way ...
Battery Tender - Battery Frequently Asked Questions
www.batterytender.com/Battery-FAQ/
Dec 26, 2015 | Cars & Trucks
How can I hook two 12 volt batteries together to produce 24 volt output. I have replaced the two older batteries but have not been able to get the two new batteries to produce the necessary 24volts
Hooking up 2 batteries (IN SERIES) will give you 24 volts. First make sure the 2 batteries are exactly the same. Do not use mismatched batteries. Hook the POSITIVE of first battery to the NEGATIVE of the second battery. Then hook your LEADS ( hot and ground) to the 2 remaining posts. That will give you 24 volts. When charging the batteries with a charger, hook the charger up to the LEAD POSTS.
Apr 26, 2015 | Boating
Hooked battery up backwards car won't start changed fusible link got power changed starter new battery
BY hooking up the battery the wrong way it is possible that you have blown up the CPU and ECM. IF you can get hold of another unit hook it up and see if it starts / fires . IF so the that will be the problem
Jan 13, 2014 | Cars & Trucks
I hooked up the battery backwards and now my radio and interior light wont come back on
you need new wiring for your radio, a new radio, new speakers, new wires going to your light and a new light. hooking up a battery wrong can destroy a car. your lucky it didn't catch fire.
Aug 10, 2013 | 1999 Kia Sephia
My battery keeps draining
-Is it new battery (Good)?
-Each battery's life cycle is Only last within 5 Years.
-Make sure battery surface is clean and dry.
-Disconnect both battery cable and hook up meter to and test voltage drop.
-Any voltage drop consistanly even the cables are disconnected...?
A: Yes. >>Bad battery. >>Replace new one.
A: No. Then hook up its cable back to and do the following:
-Hook up meter to battery and watch its voltage drop.
-Pull One Fuse at a time. If not stop, (Put the fuse back to) go to next one.
When it stop. The devices that use that line draw power.
Mai
Mar 15, 2013 | Toyota ECHO Cars & Trucks
Replaced battery, but everytime we try to hook up new battery the alarm goes off. What can we do to stop this and allow us to hook up the new battery?
usually with those after market alarm systems the installer will install a reset button under the driverside of dash. just hook up the battery then go push the button or hold it down.
Sep 15, 2011 | 1999 Toyota Camry
How to hook up 2 new batteries
hook them up in parallel, pos to pos, neg to neg from one battery to another, then pos cable to battery prs and ground cable to neg battery
Jul 29, 2010 | Renault Fuego Cars & Trucks
Installing a new battery in a Polar F4
Follow that contact (you say pin) all the way into the movement and you will find it hooked (clipped) on the plastic hook. Take tweezers and unclip it by pulling the leg outwards from hook.
Rate, please.
Mar 28, 2009 | Polar F4 Heart Rate Monitor Watch
I need to disconnect my battery from my car ,[mx5 mk 2.5 02 reg] but have not got the rodio code with my paperwork to enter when power is back on ,can you help
get 2 more battery cords and hook them to the cords that are on the the the battery right now, then hook the new cords to the new battery and disconnect the old battery
Jun 02, 2008 | Car Audio & Video
Mongoose 12v 10ah Scooter Battery Schwinn  (set Of 2) Logo
114 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
