Question about Daewoo DSA-122L Air Conditioner
After a few hrs of cooling it began to ice. What's the problem?
    President:
  • 1,515 Answers
Hi I don't know how old the unit is, but what causes the indoor unit to ice up, can be a number of things. The coil or filter up top at the indoor unit being dirty. If the coil is dirty, the blower motor can't blow enough air across the coil and will cause it to ice over. If the coil is dirty, it will need to be cleaned. If not, I would have to say that the unit is low on freon, you have a leak somewhere. You have developed a small leak and this will cause the indoor coil to ice up very quickly. On these split systems, the freon lines are screwed together and not brazed with a torch causing this to be a weak link in the system. The system is under high pressure. Anytime you have 2 freon lines connected together by threaded connections, there is a good chance they will leak over time, or right away if not done properly. I would take a good strong light and remove the cover indoors to check the condition of the coil. If it is clean, and the filter is clean, make sure you have only the fan on and the ice has melted off before you do this, and feel the force of the air coming in from the blower motor. It should be nice and strong. If this all appears to be clean and alright, then I would say you have a leak and you will need to call out a tech to do this type of job. This is all that you can do at this point. If the unit is new, lets say less then 6 months, it should still be under warranty. You would know this. I hope I have been of help to you on this, as I see this everyday. Please don't forget to rate me, and please keep me posted on the outcome. I will be here if you need me.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Oct 02, 2010
How do I fix my icemaker?
if its new it can take up to 48 hrs to produce its first ice cubes, this is due to timer in the ice maker
Nov 07, 2015 | Bosch B26FT70SNS - 800 Series Standard...
The top freezer of my Maytag refrigerator does not keep ice cream firm. It will freeze water, but ice cream is like cool whip. Help!
Check your ref/frz settings. Check the condensing coil for dust/lint/other. You may also have a defrost problem. Check back panel in frz for ice/frost. Try emptying unit and leaving it off and doors open for 24 hrs. If it starts cooling afterwords, is probably dft cycle.
Nov 22, 2010 | Maytag Refrigerators
Fridigaire top freezer has stopped cooling
It could be frosted up or the drain plugged which would cut off the air flow to refrig section. If you see any frost or ice anywhere empty the unit and let it set with doors open 24 hrs to thaw. Or take the inner panel out of the freezer to see where the blockage is. If the coil is completely frosted over you have a defrost problem and need to determine which component has failed
May 20, 2010 | Frigidaire FRT21H8 Top Freezer...
Freezer is cooling fine, but fridge is not cooling properly
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 12, 2010 | Frigidaire FRS6R4E Side by Side...
Frezzer working,freshfood side not,ok I stopped motor several times and it work four days and agin the problem. Is there a sensor in the freshfood side? or a little fan inside?Pls Help me
Hi, you got a defrost problem, when to much ice build up after few days,cooling decreases. it could either be your defrost heaters are burnt out, faulty defrost timer, or faulty defrost thermodisc, which are usually at back of freezer, you will have to remove back panel of freezer, and cary out continuity test, to see which ones are defected. the defrost timer sometimes could be found inside of refrigerator compartment or at back of ref. different models, different location, you didn't say what made ref. you got, surely you got a defrost problem, you will need a mechanic to get it check, if your days are hot, or if you got door gasket problem, or someone forgot door half open for few hrs, or excessive hot air getting into ref, could cause that too. before calling mechanic, you will need to empty ref. and unplug for few hrs, clean out all ice, surely it will work, but if problem continues, call mechanic.
Aug 07, 2009 | Refrigerators
Water/Ice Dispensor Malfunction
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure the refrigerator has the blower problem for which the problem arrises ....... please visit your service authority...........have a nice day:-)
Mar 02, 2009 | LG LRSC26920TT Side by Side Refrigerator
Ice maker not making ice
a few things, was the ice maker working before repair?? generally the ice maker need to "cool" before making ice, usually give 24 hrs to start producing ice. next perhaps the tech shut off water supply never turned back on??? bottom freezer, perhaps he had to remove the ice maker to remove the back wall of freezer and never reconnected wire harness to the back wall.
Nov 17, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is frozen
you need to defrost the ice maker for that you need to turn off the refrigerator of few hrs 6 hrs atleast
Jul 21, 2008 | GE Refrigerators
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Daewoo DSA-122L Air Conditioner Logo
67 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Dan Webster
Dan Webster
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
