Question about Maytag Refrigerators
I have a Maytag French Door refrig, bought 3/05. Am having problem with the freezer door. It pulls out about 6" then hangs up somehow. It started a couple of weeks ago with a clicking sound when it was opened. Any suggestions? Thank you, Mr. Maytag Guy! k.
  • kaymcduffee Oct 04, 2010
    Thanks for your reply but it did not help. It seems like the runner on the right side is sticking and the door won't open all the way. Anymore ideas????? Thanks! k.
  • 10,865 Answers
Hello Kay. Begin by checking the contents of the freezer to be sure that there is not some item which is sticking out too far and causing this hangup. Also check the ice maker to be sure that it is not sticking out too far. Remove the ice maker bin and check behind it too. If the problem is still not solved get a can of a penetrating lubricant and lubricate the pivot points at the top and the bottom of the door. Also lube the fridge door while you are at it. Joe
Posted on Oct 02, 2010
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
My refrigator isn't making ice, and hasn't in about 6 months?
It could be a couple of resons, I have the same problem. With my refrigator its the water tube that fills the tray freeze up. So I have to shut off the unit, leave the freezer door open for about 30 minutes or so. Then restart the unit.
Jan 31, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
I have a maytag refrig that I can not figure out how to reprogram the freezer temp and refrig temp.
https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10175444A.pdf
Page 9 how to set controls
Jul 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
How do I initiate defrost in a Maytag tri-door
Try this open the freezer door and flick the light switch 6 times, like flick, ----- flick,----- flick. If 6 does not work try 8, cant remember.
Aug 22, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
I have a bottom freezer french door mode. The
remove both crisper pans and check the return are duct opennings. next check if there's a built up frost/ice on the rear wall of the frzr. is you frzr fan blowing air? if so, there's a small window inside the refrig's freshfood side back wall towards the cieling, make sure that's open.the cover should snap off. if window/damper is open, go ahead an pour hot water down the return air ducts behind the crisper pans. they look like grill slots in one or both coners
Jul 14, 2009 | Maytag MFI2568AE Side by Side French Door...
Maytag Refrigerator is 69 degrees
You must check the evaporator fan motor in the freezer.
Is it running?
You may need to push the door switch with the freezer door open for fan to run with drawer open.
Next check the damper in the fresh food section.
Is it open?
Air circulating through?
If not, replace your damper control and thermistor.
Feb 21, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
How do you changing the water fileter
  • in case you haven't figured it out by now. open rt side door and top right corner is the filter push the little plastic tab and the housing drops down , a quarter turn counter clockwise and the filter should pull out, reinsert the new filter screwing clockwise and close housing, remember to pull water from dispenser right away you will have let air into system so some sputtering will occur till its purged
Feb 18, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
