Question about Lutron MIR-600 Remote Control
Does the lutron mir-600 work with homelink? - Lutron MIR-600 Remote Control
    Novelist:
  • 107 Answers
No, the MIR-600 uses line-of-sight infrared as its communication technology. Homelink works with radio frequency wireless technologies. The two are incompatible.
Posted on Oct 04, 2010
Why did the remote suddenly stop working?
Try disconnecting power at the source, not a switch. Wait for a minute or so and turn on the power again. This action may "reset" the receiver. You also may find that remote control is restored after a power outage. Finally, if nothing else works, you may have to install a replacement Lutron receiver.
Aug 16, 2015 | Lutron Electronics MIR-ITFS-LF-WH...
Can the Lutron MIR-600 Dimmer switch be synced with a comcast remote? And if so how?
No. A remote must be able to learn IR codes or already have the Lutron codes installed.
Dec 27, 2012 | Lutron MIR-600 Remote Control
The LED indicators on my Lutron Maestro continuously run up and down without stopping and the lights (or fan) will not work? It seems as if the entire switch is frozen... Whats the problem?
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which apparently excludes CFLs.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on nearby outlet that is on same breaker to see if line has interference.
3) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Maestro Lutron Ir Dimmer Mir-lfqthw...
I have a Meastro dimmer MAW-600 W that is installed, but the light does not turn on and the LED keeps blinking. Any idea what the problem can be?
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which excludes CFLs apparently.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on outlet on same breaker to see if line has interference.
3) I don't see MAW-600 W listed among Maestro dimmers, so I don't have that specific manual.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
4) Amazon certainly shows the MAW-600 W, in case you need a replacement.
http://www.amazon.com/Lutron-MAW600H-WH-Electronics-Maestro-Dimmer/dp/B000BPCWQE
5) Lutron has customer service numbers:
1-800-523-9466
Feb 02, 2011 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Ok i installed the Maestro IR on a switch that runs a celing fan with a light on it. i turned the power back on in the room and the light was flickering and the fan was unresponsive. please help!!
Lutron Maestro IR shows several model numbers:
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro+IR%C2%AE+dimmer
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen.
Installation manual:
http://www.lutron.com/TechnicalDocumentLibrary/030864b.pdf
If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan'
It appears this dimmer is for incandescent and Halogen lights.
Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service.
Expert will walk you through the problem for a price.
Dec 25, 2010 | Maestro Lutron MIR-600 IR Satin Color...
We have an older maestro style lutron dimmer switch with a horizontal slide button at the bottom that can turn it on and off. we are using this button to operate the light b/c the vertical...
These in-wall devices stop working and need to be replaced from time to time.
There are no repair parts.
Generally dimmers don't last as long as ordinary light switch, because they are electronic instead of mechanical.
Lutron makes the widest selection of dimmers.
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Use link above to identify dimmer.
For example Skylark dimmer.
Then google search for a replacement.
For example: single pole 600 watt lutron skylark dimmer
Or: 3-way 600 watt skylark dimmer
Lutron also makes 1800 watt dimmers for larger loads.
Add a comment any time if you need more help.
You can also take advantage of fixya phone service.
Fixya expert will talk with you via phone for a price.
Dec 24, 2010 | Lutron Electrical Supplies
MIR-600 Remote Control: i installed mir-600 one year ago, it worked fine. ...
Unfortunately, there's not a lot of black magic involved here. 99.9% chance is that the product is either wired incorrectly or that it failed during the installation or uninstallation (which is likely if either took place while power was still on).
May 18, 2010 | Lutron MIR-600 Remote Control
I purchased a replacement MA 600 3 way dimmer. The old ones had wires, this one screws. Can you tell me how they map?
http://lutron.com/CMS400/page.aspx?id=16977
The black screw is the common (either power or switch leg depending on which side of the 3-way you are working with), the brass screw is one traveler and the blue screw is a low voltage communication lead (second traveler). I have attached a link to Lutron's wiring diagram pages, just select your dimmer.
Nov 29, 2009 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Remote doesn't work, installed new batteries also.
Is there another one in the house? The best thing you can do is to first figure out if the issue is with the remote or with the MIR-600. (use one remote on that dimmer, another dimmer - than a second remote on that dimmer, and another dimmer - does the issue stay with the dimmer or the remote)? Regardless, there tech support center can help you out pretty effectively at 1-800-523-9466
Sep 30, 2009 | Lutron MIR-600 Remote Control
Lutron maestro digital fade dimmer quit working. How can i fix it?
Your issue is pretty vague. Their technical support center can help you diagnose very effectively - 1-800-523-9466
Aug 16, 2009 | Lutron MIR-600 Remote Control
Lutron MIR-600 Remote Control Logo
156 people viewed this question
Top Lutron Televison & Video Experts
Electro Med Services...
Are you a Lutron Televison and Video Expert? Answer questions, earn points and help others
