Question about Nokia 5200 Cellular Phone
Code Thank´s a lot, but could you be a little bit more specific about what i´m supposed to do with those numbers. Thank´s again!
  • 38 Answers
U should enter the numbers in ur cell where it is asking for
Posted on May 29, 2008
Store location closest to qld postcade 4510
post, code 4510 covers square kilometers and there are bound to be many stores in that area including suburbs and towns
I don't suppose that you could be a little bit more specific
Jun 15, 2017 | Office Equipment & Supplies
Trouble shooting
its the tensioner knob turn it a little bit till the stitch is back to the way its suppose\ed to be, don't turn the knob a lot ust a hair a little AT a time try the stitch each time you turn it to see if the stich is tight again. The knob has numbers on it you have to d this in straight stich setting
Apr 28, 2017 | Sew D'Lite Lightweight Portable Mechanical...
Enter your serial number:
I need an activation code for autodesk 3ds max 2010 32-bit, request code is KYLY PEKU 93VT PAKU ONGR 9QR6 005C QZ9Z I hope any one could help me thank a lot, Im looking forward of you guys! God bless us.
Feb 27, 2012 | Autodesk 3ds Max 2010 for PC
I have a Canon Canola P1016-D calculator that I have had for some 20 years. I have just now only found that when adding up a lot a numbers the unit will freeze and an "E" will come up on the...
  • "E" is a specific variable in calculus.. but on a calculator, it means the number is too high for the calc. to process. If you need to work with higher numbers, you will have to get another calculator.
  • If it does this with smaller and smaller numbers, that means the processor is wearing out, and eventually the calc. will stop working
  • Reply if you have any other questions. Good luck, Cooper. (Please leave a good review, I am doing this for a summer job)
Jul 06, 2011 | Canon Office Equipment & Supplies
Can i have a breakdown as to what would be hooked up where for the recording with this mackie mixer?
thaqts a little vague, what equitment do you have to hook up to it, specifically. i need makes and model numbers for everything you plan to hook up, microphones, amplifiers, speakers, effects processors, compressors, corssovers or varieties of electronic and acoustic instruments.
wiothout specifics, all i can say is "plug mics into whatevver mic imputs, and keyboards into whatever input, and your amps/speakers to the main outputs"
you are asking for quite a lot, try to be more specific about your external equiptment, and try to narrow your question down a bit, and i will be happy to help you out.
Nov 26, 2010 | Mackie 1202vlz3 12 Channel Mixer
I need a authorization code please- Serial Number- 1045-1090-6246-8353-3166-2968 Activation number- 1691-7278-2000-6470-4877-9686-4063 Activation type- Normal: 194:13 email- disneyfanforever@hotmail.co.uk
I also need authorization code please Serial Number: 1326-1554-3996-0749-1160-7466, Activation Number: 3603-8891-8148-7459-9173-9174-5471, Activation type: Normal: 194:8 Email: sanjeevchhetri@gmail.com Thank you
Oct 02, 2010 | Adobe Computers & Internet
Wiil part #44554-03 fit a 2004XL1200custom?this is suppose to be a 19inch front wheel.the stock wheel is a 21inch.thank you
Could not find that specific part number in my catalog, but assuming it is a SuperGlide front wheel, yes it will. You may have to buy the model-specific wheel installation kit. But be advised, the new wheel will drop your front end a bit and the clearance to the front fender may look a bit weird. Most, but not all, front wheels from 2000 up to about 06?? will interchange with a spacer/axle swap. Make sure your brake rotor spacing is the same too. I know between 1999 and 2000 it was changed. Not sure if there were any running changes in between 2000 and 06.
Nov 11, 2009 | 2004 Harley Davidson XL 1200 C Sportster...
What screw do i turn to lower the beater? & what direction? (be very specific)
There is one lone screw on the post behind the bowl. just turn it a little bit and test the clearance manually as a small adjustment is generally all that is needed.
May 21, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Problem entering Subscription Key/Reneewal Code
try to enter the old serial number or reg key if it doesnt work then u go look for a crack or a back door.
search in http://crackhell.com/ if ud find the crack or serial for it
thank u
May 26, 2008 | Computers & Internet
Emptied toner waste and now I'm supposed to do an Sp 83 or Sm 83 to clear the counter?
ok, you need to enter service program as follows Press 7 key.Press 1 key.Hold down the stop/clear key until you see "." in the upper left corner of the display. Release the clear/stop key. press the clear/stop key again. Press the lighter key. The number "5" will now flash in the display.Enter "96" using the number keys.When you have enter the code,Press Print, cut copier off then on.
May 12, 2008 | Office Equipment & Supplies
Nokia 5200 Cellular Phone Logo
21 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
