Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Brush is rattling
The brush sounds like it is hitting something when it is on the "x-lo" setting. It gets a little better sounding as you raise it up. This started right after I got a ribbon wrapped around the end of the brush and pulled it out. Help?
  • Anonymous Jun 23, 2008
    How do I remove the plate from the bottom in order to remove the brush.?
    stewartclans@yahoo.com
    President:
  • 1,673 Answers
If this model has a cogged belt, it may need to replaced. When you cath stuff in the roller some times cogs get stripped off of the belt.
Posted on May 26, 2008
How do I Pull apart a Simplicity Synchrony?
The noise is likely the brush roll or the lower motor fan if you only hear it when you turn on the brush roll. Remove the bottom plate to examine the brush roll, there are screws on the bottom of the vacuum that must be removed so that the top nozzle housing cover can be removed. Remove the screws to take the cover off the nozzle housing from the brushroll to the lower motor so you will be able to inspect the fan in the lower motor. You have a high quality precision vacuum that is not easy to repair without proper training. It may save money and provide better results to have it repaired by a qualified Simplicity or Riccar repair shop.
Jan 23, 2017 | Simplicity Vacuums
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
I have a Dyson dc17 I have changed the belt cleaned the brush bar clean the bar motor reset the switch and still when i vacuum the brush bar just stops does not rattle. does not do it on bare floors or...
hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Sounds like the beater bar hits the front plastic makes a loud awful noise
Hi Cathy,
Your DC33's brush control is designed to make a ratcheting sound to warn you if something is jamming the brush bar. You should be able to resolve this by making sure the cleaner head is free of any obstructions, and removing any threads or hair from around the brush bar. For guidance in doing this, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc33/dc33-multi-floor/dc33-maintaining-your-dyson-machine/how-to-remove-a-blockage/from-the-brushbar/removing-debris-from-the-brushbar
This should resolve the issue, but if you're still concerned about the machine after following these steps, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 27, 2012 | Dyson DC33 Animal Bagless Upright Vacuum
Whiel vacuuming i accidentally vacuumed over the cord and it got stuck around the brush and it melted down to the wires. After taking the brush off and removing the melted rubber I put it back together and...
Before you do anything, did you wrap the wires with electrical tape? If not, you could get shocked, or at the very worse, burn it up.
As far as the thud sound goes, it sounds like you might have bent the brush and it's rubbing on something where it's bent. try to straighten it. Otherwise, are you sure you got all the rubber out?
Good luck.
Handie Andie
Mar 25, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
My Dyson CDC14 Animal just started making a wierd sound coming from the rotating brush area. I already cleaned around the brush, sounds like a fast rattling sound.
Something could be jammed, or not rotating freely, maybe an improper alignment with the brushes, or a blocakage within them. Try to re adjust the brushes :)
Jan 27, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Just bought a hoover upright windtunnel cylonic weird noise
no, brush roller shouldn't be touching anything,its under warrenty so take it to a hoover repair shop with your proof of purchase and they will fix it at no cost to you.something like that they might be able to fix it while your there because it won't take long. please leave feedback
Jan 08, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Dec 20, 2008 | Hoover U6630-900 WindTunnel Bagless...
Dyson DC17 now noisy and harsh click
I am having the same issue with the clicking noise when I try to open mine. Dyson has told me it's "not their problem" What it is is the little curved part that moves to change the suction to the wand vs the brush is catching on the tab that holds it up. It's out of alignment somewhat. Mine has been so bad that it has fallen off each time I open the vacumm. A costly repair of $172 each time. I can't get the piece put back on by myself.
The repair man finally filed down the little tab at the top that it hooks to when you set the vacumm upright. The curved piece is still falling off, so its back to the shop again. Dyson, still swears it's not their issue. The heck it isn't!
My vacumm is the same age as yours. I love it, we have 3 very large dogs that shed heavily, the vacum gets used 3x a day. It's the wear and tear on that tab. I'd love to know if you can get dyson to listen to these complaints any better than I have.
The sound with the brush- is something caught inbetween the brush and the cover? Do you have any smell? I had to replace my "lifetime guarenteed" belt.
Good luck
Shell
Sep 14, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
77 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
