Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Blue on the edge of picture and 10 to 15 blue dots in the center of picture,has been getting worse
  • 1,476 Answers
Pamjenkins72,
I hate to be the bearer of bad news but you have an optical engine going bad, and when it happens in a Sony it is very expensive to replace. Your units optical block part number is A-1084-658-A and the cost is $620.00 US.
If you want to go ahead with the repair anyway, I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, where to get the parts at the best price and how to perform the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 02, 2010
Can a blue dot on a tv screen get worse or stay the same.
One little blue dot is not enough to warranty the television. If you read all the documents on the set, it will tell you that some imperfections in the display are allowed. The good news is that it wont get any worse
Feb 23, 2015 | Element Electronics Element 50" Class...
Sony KLV32T400A LCD TV. Colour Problem With Black colour of hair showing blue. Other than that the TV is fine. What solution
Hello, Sounds like an LVDS Cable or T-con Board.
Usually this will slowly get worse until it is repaired. It is caused by a failing T-con (Control) Board or connecting cable. T-Con Will Need replacement. This picture show's more extreme T-con board failures
Feb 18, 2012 | Sony Televison & Video
How to put up a tent- ozark trails 16x12
I have this tent and have successfully put it up a few times. It's a big tent but it's frustrating to put up sometimes. Plan on having several people to help you. I find that it greatly helps if there are a total of 3-4 of you.
The poles are color coded. The center support are red rods. The two side supports are blue with the graphite looking rod that goes through the tent.
Spread the tent out on the ground and try to square it up and make it even. Run the center pole through the top and connect to the curved pieces which then connect to red dot poles on the side. Hoist the whole thing up. Have two people hold those poles for a while.
Get the bue poles into the black couplings and put the graphite looking rod through the tent. It will be a little tight. Hoist the blue poles into position. The bottom of the blue dot poles should be about two feet from the center. They extend outwards at about a 30 degree angle. Keep your center people holding the center poles and let the two blue dot pole section extend outwards. You'll start to see a tent shape. Your center holder people may need to keep and eye on the poles.
Now, start trying to get some stakes in. Work the corners. Once those are in and things start getting tight, it should start to hold on its own. Work all the stakes in and make adjustments to all the poles as necessary.
Extend the red dot poles up until the roof is at the proper height. I tend to do this last.
The fly basic basically clips on into holes on the blue dot poles.
It's kind of a pain to set up but its a big tent and works well once it is up. Good luck.
I took a ton of pictures after I got it up the first time. As I took it down, I shot the pictures. Then, I reverse the order and printed them to a book and now sort of use that as my manual.
Have fun.
May 20, 2010 | Computers & Internet
Started with blue streaking and now there are tiny blue dots
you cannot do it yourself, however sony will do it for free, call 1-888-993-7669 and inquire about the optical block program. good luck.
Aug 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue section (corner) and blue dots
This set has no internal manual adjustments for color. The Tracking or B&W balance is accessed via the service menu. I don't suggest you attempt to adjust without instrumentation. the trouble with your set is not an adjustment. Most likely the Optics are at fault. This model has had issues with filters in the optics being destroyed over time by the lamp. The blue haze will get worse and continue to grow over the whole picture. The only option is to remove the Optics (light engine) and sent it out to be rebuilt.
Apr 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue line problem with Sony Grand WEGA KDF-55WF655 Rear Projection TV.
We had the free repair from SONY for the blue dots and splotches. It works great now but you need to hurry and contact them as the offer expires I believe in December.
Sep 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Blue dots
You have a bad blue LCD in the light engine. Replacement of the light engine is the only fix and it usually will continue to get worse over time
Feb 13, 2007 | LG RU-44SZ51D 44" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
