Question about Agfa Cyber-shot DSC-W150 Digital Camera
When i turn my camera on a screen pops up that says turn off and on again. when i do that it comes up with the same thing. What should i do?
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Agfa service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 02, 2010
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
My mount flash from my Canon EOS 60 D is not popping up when I am taking a picture. The screen is telling me to turn off and on the camera and I do that. When I tried again the same thing happens. I...
This is usually caused by sticky liquid spillage or impact. Try popping up the flash with your finger nail when it tries to rise and then cleaning out with Windex on a Q-tip. Sometimes you get rust on the pivot screw on the release side.
Sep 19, 2013 | Canon Cameras
I have an lg cosmos touch. When I turn my camera on it loads for like two or three seconds then this thing pops up it says camera start error. I've tried turning it off then back on again that...
RESET YOUR MOBILE TO FACTORY DEFUALT BY TYPING THE CODE BELOW ON YOUR MAIN SCREEN:
2945#*#
AFTER YOU TYPE IT ,MANY OPTIONS WILL APPEAR ON SCREEN,CHOOSE FACTORY RESET
Jun 03, 2011 | Cell Phones
The lens does not stop popping in and out plus it says to turn off and on again
hi there
turn camera on, gently take hold of the end of the lense and pull toward you twisting it a few times, be gentle dont make it pop, you may howeveer hear it click. then turn off and on again the problem should be solved.
Oct 28, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Power on Problem
please make sure the batteries you are using are genuine.
Jul 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Camera
It a lens misalignment try tapping the lens gently in an opposite direction the camera dropped on and that should pop the gear back into place
May 12, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Yeah, try to tapp the lens assembly with finger when it keeps going in and out.
May 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Lumix / Panasonic fixed lens Digital SLR problem.
try to help the lens come out by pulling it very very lightly...you should here a pop.
Mar 25, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC LZ2
My camera is a Lumix DMC - LS70 and the same thing was happening to me, the camera kept telling me to turn it off which never solved the problem and the lens never closed when the camera turned off. What i did was, i zoomed out as i turned the camera on (while it was in a picture taking mode) and it corrected itself. Try it and see what happens.
Sep 23, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Agfa Cyber-shot DSC-W150  Digital Camera Logo
71 people viewed this question
Top Agfa Cameras Experts
CHIVOIU...
CHIVOIU...
Are you an Agfa Camera Expert? Answer questions, earn points and help others
