Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Furnace manual I have an amana 80 sse model # guic115cx40- I am looking for a service manual because the pressure switch is stuck open. Please advise
  • quocttruong Jun 20, 2008
    I have the same amana 80 sse, and the AC is not blowing air into the room as usual (seems like 1% of the blowing strength as compared to 100% at the normal blowing speed. It seems there is very faint cool air blowing but not as strong as before? Any advice? Thanks.
    JT, Alexandria
  • 700 Answers
Here's the link for your problem and I hope that it helpshttp://johnstonesupply9.com/TechDocs/Amana/Gas%20Furnaces/GCIC%20Gas%20Furnace/GUIC%20GCIC%20TECH%20INFO.pdf Thanks for unis FixYa!
Posted on Dec 23, 2008
    Problem Solver:
  • 15 Answers
The reversing valve is stuck!
Posted on Dec 02, 2008
Will a wireless thermostat work with my amana command 80 sse furnace?
Yes. A wireless thermostat will work on your Amana furnace. I like the Honeywell wireless thermostats. The only problem I have had is exceeding the distance between the wireless thermostats location and the control module that you mount and wire up next to the furnace.
Feb 07, 2018 | Amana Heating & Cooling
Amana model ACS4250A (slide in). How do I remove the front panel?
[PDF]80-90 FURNACE SERVICE MANUAL.pdf - Johnstone Supply
johnstonesupply9.com/.../Amana/Gas%20Furnaces/GCCA%20Gas%20Fu...
Instructions. This manual is to be used by qualified HVAC technicians only. Amana .... Gas Furnace Upflow/Horizontal Induced Draft A Air Command 80 SSE.
Nov 06, 2015 | Kitchen Ranges
How do i reset power to thermostat from amana furnace is there a reset for controls?
The manual says it should automatically reset. However to manual reset the unit it says to "interrupt" the power supply. --which I think means unplug/turn off electric to unit for 20 seconds. If you do not have the manual go the manuf website and download it. --Also, this is a Goodman unit. If it does not reset something else it wrong that is preventing the unit from starting for safety reasons.
Sep 01, 2014 | Amana GMH81405DN 140,000 BTU 80% Gas...
Lp furnance ignites for 3seconds then shut off.
A pressure switch code means there is an unsafe condition that should be looked at by a competent service tech. Sometimes there is a switch failure, but most of the time there is an unsafe condition.
Jan 03, 2014 | Comfortmaker G8MXN1102120A 110,000 BTU 80%...
Amana 80 sse flame rollout sensed what does this mean and how do I fix.
The flame rollout switch is located in the burner box on the left side on an upflow model. There are two wires connected to it .between the two connections is a small red button. Depress this until you here a small click. This should reset the switch. These
switches usually open because the flame is "rolling" back instead of being drawn into the furnace.start furnace and check for flame rollout.when the main blower fan comes on if you notice any change in the flame turn furnace off and call a qualified service person as this could indicate a cracked heat exchanger and could cause carbon monoxide to enter the house a potentially dangerous situation. I strongly urge anyone with a gas appliance installed to have a good carbon monoxide(CO) detector installed also. Hope this helps.
Dec 10, 2013 | Heating & Cooling
Amana 80 sse
Amana aircondition window unit wouldnt turn on. E2 indicator light was on. I turned off breakers and turned them back on as suggested for an Amana furnace. Yay, it works now. Thank you.
Jan 19, 2012 | Amana Heating & Cooling
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
My amana 80 sse furnace will not heat. looks like furnace light is off. what can i do to reset it. thanks
Turn off breaker. Turn it back on. If furnace is completely dead still, change your transformer. It's cheap..
Dec 11, 2008 | Heating & Cooling
Need to know what size Blower motor I need for and Amana SSE 80 furnace.
The blower size is selected based on the details of your home. The size of the motor must match the tonnage of the A/C. The tonnage of the A/C will be determined with a heat gain/loss calculation.I believe there are at least 2 options for this furnace 3 Ton, and 4Ton.
Jul 02, 2008 | Amana Heating & Cooling
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
866 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
