Question about Makita Saws
How do i replace my tension spring on my makita 5007F circular saw? i put it on but it keeps falling off. what step am i missing?
  • 2,176 Answers
Is the spring stretched?? there are 2 holes one in the lower guard and one in the upper guard assembly towards the back that you have to put the bend of the spring in
Posted on Oct 03, 2010
I have a Makita circular saw model 5007F. When plugged in the light that you follow lights up but when I pull the switch it will not do anything. I'm wondering if the switch is bad?
Check the brushes for the motor first, make sure they're in good shape, or replace them as they're fairly inexpensive, this is the most common issue, especially if you picked it up second hand, or have been using it for a while. Then, yes, I would try the switch.
Unless to motor is shot, which you might be able to smell it and tell if it's burnt, it's most likely either the brushes, or the switch. Of course, I'm presuming you're using the thumb lock out before you pull the switch ;-) but since you didn't say... and yes, there are some people... :-)
Mar 22, 2017 | Makita Saws
How do I fix my spring loaded lower blade guard on my circular saw
I need to know the make and model of your saw in order to help you.
Jan 05, 2015 | Saws
What is the spring for in the 2000w makita circular saw
Other than carbon brush springs, the only other spring that I know of on a circular saw is for the blade guard so that it will automatically return to cover the blade after you make the cut. There should be a hook or a bend in each end of the spring and each end has a certain spot where it hooks so that it pulls the blade guard back in place.
Jul 13, 2014 | Makita Saws
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
My Makita circular power saw works then stops working, then starts again. Why is this happening?
Things to check: With the saw running, safely grab the cord by the boot and pull and twist it around. This is where a break frequently occurs inside the cord and when the saw is held in certain positions the break will either open or close. If the cord's OK, unplug the saw and remove the brush caps and check the brushes. If the brushes are less than 1/4" long or the springs are burnt or broke they won't make good contact with the armature. If the cord & brushes are OK your next recourse is to replace the switch (Makita PN 651172-0).
Jan 22, 2013 | Makita 7 1/4" Circular Saw 5007NB
Brushes arcing
Brushes arc for several reasons. If the spring over heated and lost its tension or the copper line from the brush to the cap broke/burnt off or the brush wore down too far to be pressed on the armature properly. The replacement brushes you need are Makita part number CB-124. If you still have exessive sparking after replacing the brushes you may have a bad commutator on the armature. The only way to fix that is to replace the armature, Makita part number 512831-0.
Oct 09, 2012 | Makita 5005BA 5-1/2 inch Circular Saw
Makita ls1013fl I need instructions on how to install
I installed it by looking at the parts pictures in the manual and experimenting. Thanks for the try at helping me.
Joe
Dec 14, 2008 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Saws Logo
444 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
