Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Where do i plug in the telephone wires from the printer, into the comp.
    Sergeant:
    Champion:
  • 251 Answers
You don't. The telephone wire connects the printer to the telephone jack in the wall so that you can send & receive faxes.
Posted on Oct 02, 2010
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 3030 All-In-One Printer
When I plug the telephone line into the Fax machine the telephone line goes dead
Verify that telephone cord from the wall is plugged into fax port labeled LINE. The port labeled PHONE is for a spare telephone set.
Dec 18, 2012 | HP Photosmart C6150 Wireless All-in-one...
HP Officejet Pro L7650
The problem could be your web browser and its settings. You can try using another computer, or another browser. If you are using Internet Explorer, dry downloadingFirefox and accessing the router again. Hope this helps.Can you tell me which Internet Service Provider having you use. If your physical connectivity is pour or every minute or while reconnect your physical connectivity then your router also reconnect your ISP so router ask you password conformation for that.
If you using DSL connection then you do first that check your telephone wire physical connectivity and also if you have multimeter than check telephone wire voltage if is not stable than your telephone connectivitiy is pour so called telephone mechenic for that.
if everything is ok than ask your router company.
Dec 05, 2011 | Linksys Wireless-G Broadband Router
I have the canon mx870. I cannot get a dial tone. We've tested the the telephone jack and the wires with our telephone and theose work fine. How do I get a dial tone?
Check to make sure you've got the phone cord plugged into the correct port on the printer. There will be one with a picture of a telephone and another with a picture of a wall jack. Use the wall jack port and you should get a dialtone.
May 06, 2011 | Canon PIXMA MX870 Wireless Office...
My printer wont print. screen say it is off line or not connected. please help. i have looked at back of printer and hard drive and canno find a port to plug the wire into. The end of the wire has a plug...
First check the usb cable to be ok,the connection on the printer-computer be ok,try to change the usb cable,reinstall the driver,if the problem persist maybe is the logic board broken.
Mar 24, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Which telephone port do i put the line in
These are typically marked with a small Phone Icon - meant to connect the telephone handset, or LINE meant for the wire to the wall. look carefully its written on the jacks, however be careful, some printers also have a LAN port that is similar but larger than a phone cord plug , which is made to connect to your homes network. If this helps please click on the thumbs up for response. Thanks
Aug 26, 2010 | Canon PIXMA® MP530 All-In-One Printer
Hooking up cables and phone line to use the Fax on the P3150
Find a telephone wall-jack.
Buy a 1-to-2 telephone-splitter -- one end plugs into the wall-jack, and the other end provides 2 telephone-jacks.
Connect your telephone to one of those 2 jacks.
Connect your All-In-One to the other of those 2 jacks.
Be sure to use a 4-wire telephone-cable, not an 8-wire network-cable.
Feb 03, 2010 | Lexmark P3150 All-In-One InkJet Printer
Cant get fax to work
You should be able to use it just like a telephone. Make sure you have the phone wire plugged into the in jack and the telephone unit wire plugged into the out wire. If it's plugged in backwards, it won't work. Put your papers in, press the number you want and press start or send.
Jan 03, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Missing cd to install
the settings should still be installed on your comp acces controll panel and select printer and faxes this should give you a list of printers yours should be in this list if not have you still got disk if you havent the you could access controll paned and select hardware devices and make sure printer is plugged in then let your comp search for new devices when its finished select the printer from the list if you dont have disk it will ask if you have it select no then the comp will serarch for the setting for you but it should still be installed on your comp anyway. have you tried just plugging it in and trying it to see if it works cus your comp might just set itself up any way i hope this is some help to you
Nov 19, 2007 | Dell 1700n Laser Printer
Software and using Lexmark X750
there are not many connections for this printer.. when u say "I need to make sure the printer is connected right". U need the power supply to be plugged in. The usb from the printer to the comp. and the telephone wire from the wall outlet to the "Line" jack behined the printer.. if u have an answering machine.. then connect it to the ext port on the back of the printer.. set the answering machine to 3 rings and X7350 to 5 rings... thats all about the connections... If u dont have a driver CD... then download the drivers from www.lexmark.com for vista
Sep 19, 2007 | Lexmark X7350 All-In-One InkJet Printer
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
