Question about Rotary Hammer Drill Metabo Uhe 28 Multi W/2 Chucks
Metabo drill sbe1010plus just stopped working
My metabo khe2444 stopped working while i was drilling, what could be the common cause?
If it's fairly new, the electronic switch/speed control is the most likely thing to go out. Check and see if you can get full speed out of it. If so, then it's definitely the speed control.
If it's been used a lot, then it could be the brushes or bearings/bushings.
Here is one of the companies that sell parts for it. I'm including this so you can see a diagram. (I've never bought anything from this company, I'm not trying to promote them.)
http://www.mtmc.co.uk/Metabo-KHE-2444-/-06154000-/-EU-230V-Spare-Parts__p-103435.aspx
Nov 07, 2016 | Metabo Drills
I have a 15.6v NiCad metabo drill can you replace 15.6v battery with the 18v which fits exactly the same in the drill
No the motor is only rated for the voltage that came with it it might work for a little bit but will burn it up
Jul 03, 2015 | Metabo Drills
Metabo uhe 28 multi code
http://www.metabo.com/International-Homepage-english-The-craftsman-s-brands-world.2786.0.html?&L=2786 You have no question but I do see the name metabo so hope this helps. It's the Metabo factory site where you can get parts breakdowns and more.
Jan 04, 2013 | Rotary Hammer Drill Metabo Uhe 28 Multi...
Where can I buy a forward/reverse switch for a metabo right angle drill BE 622
Service Centers are listed on the Metabo Web Site. go to Metabo.US, then Services/Support, repairs and spare parts and in the center of the page click "Service Center". input your 5 digit zip code and it will offer you a list of all local groups that support the Metabo line.
Apr 05, 2012 | Metabo Drills
Red light comes on after a couple of seconds and the drill stops working
Hi did u get this fixed my one does the same battery say it's full but red light comes on drill stops cheers
Apr 03, 2012 | Metabo 600190520 KHA24 24V Cordless...
Drill does not work when i press the trigger
Did you take a look at the carbon brushes?. Metabo has what they call Auto stop Carbon brushes. so if they are worn down they will pop away from the motor and the drill will simply not run. this happens when the brushes are basically worn out.
Mar 16, 2012 | Metabo SBE1010PlusC 1/2" 0 900/0 2,600 Rpm...
1/2" metabo hammer drill-
Did you check the carbon brushes?
May 17, 2011 | Metabo Drills
It will not work with my power inverter in my truck, but it works when used on a regular 120v outlet. My power saw and my HILTI Drill work but the METABO UHE 28 Multi just will not work at all??? WHY ???
The inverter isn't putting up enough power to drive the metabo. You may be able to give it a "running start" by rotating the blade along a board while pulling the trigger. This isn't a good practice, however, as the board or the saw could slip, so be doubly careful if you try something like this. Your best choice would be to get a bigger inverter.
Best regards, (and be careful), --W/D--
Feb 06, 2011 | Rotary Hammer Drill Metabo Uhe 28 Multi...
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
Jun 03, 2010 | Metabo Drills
Hi, i hqave METABO 523 hammer drill that the
You're welcome to ship the unit to me for repair.
Contact me at info@taeckertindustries.com for more information
Nov 05, 2009 | Metabo Air Tools & Compressors
Rotary Hammer Drill Metabo Uhe 28 Multi W/2 Chucks Logo
54 people viewed this question
Top Rotary Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Drill Expert? Answer questions, earn points and help others
