Question about RCA HD61W66 61" Projection HDTV
Internet says to use settings and adjust the convergence but i can not even get anything that says settings. i cant adjust it if i dont have access to it
  • 1,476 Answers
209petersmit,
This is a common problem with the RCA ITC222 chassis. I have a tip at http://www.fixya.com/support/r5119668-fix_convergence_problems_rca_chassis which will help solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 02, 2010
I cant do anything, recieve text messages or even get internet access
To send and recieve massages.
1) Go to messages.
2) Select message setting.
3) Select reply via same center, It should be YES always.
For internet access you need to contact your service provider and ask them to provide the settings for your Handset, Save the settings and you will be able to browse.
Thank you for using Fixya.
Nov 16, 2009 | Samsung BlackJack II Smartphone
How To Adjust Convergence - Zenth Z25X225
no you cant do that.in service mode you dont have that option for this tv.you only have this option at projection tv-s
Jan 06, 2009 | Zenith B27A11Z 27" TV
Philips 60 inch projection hdtv
O K, the misalignment is usually caused by a failure in the convergence output circuit. If the customer convergence alignment is no help then the outputs ic's are suspect.
Jan 03, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Acer 5050-5430 internet
If you have any antivirus check the settings that can restrict access of internet and also check the parental controls in the system.You can call the suport line of the antivirus software by visiting their website and getting their number.
May 27, 2008 | Acer Aspire 5050 5430 Laptop
Adjusting convergence grid
i correct grid will look all white. all colors aligned up.
you should be able to move the lines with the remote. and you cant burn anything out by doing convergence.
Jan 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence Issue...Toshiba TheaterVision HD 55H70
You probaly should be able to access the controls for that through the service menue. I dont have that info. However you can get a service manual for 10.99 at the following link, and if you purchase one they will mail it to you, unless you go back to the site and click on the contact them link and request that it be emailed to you. they also offer free support with the purchase of a manual so they can help you diagnose your set. I am one of their techs also. Heres the Link.
http://servicemanuals.vstore.ca/
Jan 16, 2008 | Toshiba 55H70 55" Rear Projection...
Misaligned Convergence
Is anenvolved job to repair a convergence problem,the way to go about it is to locate the convergence amplifier IC's,one for each color(red green,blue)check for loose conections at the ic's legs,after resoldering all the legs see if an improvement is present if it gets better you will be able to adjust from the custumer controls,but if no improvement the Ic's will have to be replaced.Some units have a separete board were you can adjust convergence after replacing the Ic's and other units you have to access the service menu to be able to do the adjustments but just doing this adjustments can be very challeging even for a train technician,I would suggest you seek assistance from a servicer and get an estimate.
Oct 01, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Convergence adjustments codes with remote control
If your talking about a service menu, NEVER ever unless you have the service manual, go into the service menu and change anything to try to fix a problem the service menu is there to adjust sets at instalationsd and not when a problem, occours and when theres a smell. common sense tells you something is wrong and burnt up. So how is a service menu that you have no clue what to do with going to help you fix a set? Im sorry man but wake up and smell the coffee. what makes you a service tech after your set breaks down.,. Oh by the way there is NO such thing as a "CODE" to fix anything in your set. There is a service menu with settings to adjust things like convergence and vertical and tunning of channels, ect ect. Get a manual and follow it if you want to try a "code". you can get one at http://www.service manuals.net Then you will need to call a tech as your set is a solid state set with No user replaceable parts inside them. Please dont risk your life trying to fix a TV set as there is a lot of High Voltage inside these sets even when they are unplugged.
Sep 13, 2006 | Philips 55PP9401 55" Rear Projection...
RCA HD61W66 61" Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
