Question about Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW
My freezer is about 2 years old. I opened it up this morning and found that about half my stuff had thawed (meat still mostly frozen). It was closed and gasket seals fine when I examined it. I turned the freezer know up from 3 to 5 and unplugged it and replugged it. What is the life expectancy of this unit ?
  • 98 Answers
About 5 years
Posted on Oct 04, 2010
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
May 19, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Continuously running freezer
Hi, The picture I get shows the temp control in the uppr left hand corner. It should be set to half of whatever is on the dial.
I had about eight different possiblities on model #. Could I get the whole # and look this up again?
May 31, 2009 | Frigidaire 19.53 cu. ft. Commercial...
Freezer door left open
Hello Captain rose,
Did you turn off the freezer and then pull the plug?
Try this again. Turn off the freezer then pull the plug for 4 minutes, plug it back in and turn it on.
Do you hear the compressor turn on?
It should only take 24 hours max. to get back to full temperature!
If this does not help and you hear no compressor, especially if it is an old freezer .
They may have burned out the old compressor by causing it to work 2 hours straight .
Rather than cycling off and on every half hour or so!
If it was an old freezer, so it means it was on its last legs and would have happened some time soon any way!
Here is an article I read abut the age of refrigerators and freezers.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 17, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Meat freezer burns
Hi,tomonbow
ngafm at your service,
You said,you are getting freezer burn in only two days, right?
Are you putting the meat in proper freezer bags and squeezing
air out as you zip lock the bag?
If you do not use proper freezer bags you will always get freezer burn on meats!
WAIT ! This will not happen in two days!
Seems to me something else has happened to your meat prior to your purchase and it probably is not the freezer at fault.
If it happens to meat that you feel was not frozen when you bought it, check with the store of purchase to see if it came into them frozen before it was put in their refrigerator case!
Most super markets receive cases of frozen meat and then put them in the walk in refrigerator, or refrigerator case to present them for sale to the customers and they defrost in the case.
Then we think we are buying meat that is fresh and never been frozen!
Fresh meat will not freezer burn in 2 days unless it has happened previously to the time you bought it.
Also when you freeze any meat you buy, repack it in proper freezer bags and not just any zip lock bag!
But I believe it happened before you bought it.
And i'll bet it all came from the same store.
that's why some people shop at a butcher shop or Costco type store where the meat is fresher and sells out faster!
Bless you.
ngafm
Please give me a good rating before you sign off.
Thank You.
Let me know the verdict. I think I'm right on target!
Do some investigating and ask the store some hard questions!
Sep 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Deep freezer thawed out
the last one i did was a chest freezer i froze the stuff then turned it off let it start to melt and pulled it out in one peice dan
Jul 21, 2008 | Freezers
Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Hotpoint FZA50 Freezer not cold enough
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Jul 10, 2007 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW Logo
220 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
john mabry
Andrew Taylor
Andrew Taylor
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
