Think you'll need to recode security system
Check for spark
see this tip: http://www.fixya.com/cars/r6223989-ignition_coil_doesn_t_spark
Let us know if you have more questions.
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition coil or
injectors getting cracked or dirty and needs to be cleaned.
To
confirm the problem, the basic troubleshooting is required.
From
start to end troubleshooting these problems I suggest you
to check the help link below and follow its procedure: -----
Mostly all types
of car no start problems are discussed here with solutions:--------
CAR NO START: ENGINE NOT TURNING
OVER:
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-no-start-engine-not-turning-over.html
These will help.
Thanks,.
