Kenmore 23513 Progressive Bagged Canister Vacuum
Problem for Kenmore 23513 Progressive Bagged Canister Vacuum
Brush won't turn
By Cerf on May 26, 2008
The brush of our Kenmore just stopped turning. To the untrained eye, it seems as if it is "off" (one side of the brush not completely where it should be). Vaccum repair shop will charge us $130 to repair. Could we do this ourselves?
Same Problem
Sep 10, 2008
-   how to change belt-   avalon4
Jul 30, 2008
-   I have a similar problem with my Kenmore 116.52650300C vacuum. The brush turns intermitently. Sounds like a be off or streched. I tried to get into the head and have succeed in getting the rubber bumper off and cannot get the head to come apart. There are some plastic snaps but I can't seem to get them all to release at the same time. Any suggestions.-   kwinscho
Solution #1
posted on May 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Remove the drive belt and check the rod coming out the motor for operation when the unit is in the on position. If the motor is turning the motor is not at fault but good. Turn off unit! Next, try to turn the brush by hand. If it is hard to turn check both sides
(the ends) for hair build up. It could possibly be loaded with hair or some other type of string like material that has accumulated over the years and is restricting the movement of the brush. Also check the bearings on the ends too.
Good Luck
Popular Solutions for Kenmore 23513 Progressive
Questions and Unsolved Problems for Kenmore 23513 Progressive
Do you recommend Kenmore 23513 Progressive Bagged Canister Vacuum?
Answer
Answer
Can I take the rotating brush out of the tool in which it is placed when cleaning a rug? It seems... (More)
Answer
The unit seems to work normally but picks up only the very fine dusty dirt in the slide-out tray,... (More)
Answer
i bought the hose now how do you take apart the end by the canister, it looks all molded together ?... (More)
Answer
I changed the bag, checked the tube for blockages and the performance light will not go off and it... (More)
Answer
My mom was vaccuming and she sucked my dogs ball up in the roller, it is jammed behind it and I cant... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
