Question about GE GSH25JFT
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Freezer bins keep icing up
Freezing over of freezer bins may be caused by warm moist air drawn into freezer by the ice chute door being stuck open or door seals being defective. Also if the defrost drain is clogged with sludge or ice behind the rear panel where the evaporator is located. Are you sure that model number DSS25KSTSS is the correct model number? Do you see ice forming on the floor of the freezer? I will be here to answer your questions, Thanks Sea Breeze
Leaking Refrigerators
Jan 29, 2013 | GE Adora DSS25KSTSS Stainless Steel Side...
What is the ideal temp setting in GE side by side refrigirator. I have Freezer (0-9) Refrigirator (0-9) There was ice on the Freezer wall and the service guy replaced the defrost thermostat recently
If replacing the defrost thermostat fixed the icing problem that doesn't indicate your settings are wrong. But the desired temp in the freezer is from 0 to 10 degrees and in the fridge around 35 degrees.The actual number on your dial depends on the personal use. Use a thermometer to check it and allow 24 hours after changing it to check it.
May 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE refrigerator, the refrigerator part of the fridge went warm and will not cool, the freezer part is cool but will not freeze ... what do i do to fix this situation?
where is the freezer?top,bottom or side by side and what is the model number.first off when you open the freezer door do you hear the fan blowing,also touch the back inside wall of the freezer,is there like ice or snow on it,if so you have a defrost problem.G,E, has had a lot of problems with the computer boards,send the model number and let me know what you find and i can help you better
Dec 03, 2010 | GE Refrigerators
GE refrigirator constantly changes temprature
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Oct 25, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a side by side refrigerator and the freezer is not cooling, what do you think the problem is?
if the refigerator and the freezer are warm,i'd have to say you have a bad computer board,they go on the ge's all the time,let me know if there's ice on the back wall inside the freezer or is it warm in both sides,also send the model number,it should be on the right side wall in the fridge up near the ceiling or if it's older it could be down near the bottom hindge on the fridge door
Sep 01, 2010 | GE Refrigerators
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
Jun 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
GE GSH25JFT Logo
320 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
