Question about Maytag MGD6400T Gas Dryer
Dryer gets hot for a couple of minutes then goes cold
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 02, 2010
Dryer hot at first and then stay cold
Sounds like the thermocouple needs replaced. When ever the couple doesn't make enough electricity the gas valve is shut down automatically. Sounds like your thermocouple is right at the threshold of minimum voltage and doesn't generate enough voltage to keep valve open.
If not that try YouTube for some good diagnostic videos:
https://www.youtube.com/results?search_query=Whirlpool+gas+dryer+pilot+light+goes+out+quickly+or+doesn%27t+stay+on
Oct 28, 2015 | Whirlpool Dryers
Aeg57800 heats up then goes cold#
If it does this repeatedly, it sounds like it's tripping a thermal protection device. You may have an excessive buildup of lint in the vent duct and/or the dryer itself.
Apr 23, 2014 | Dryers
Why is my dryer blowing out cold air?
It sounds as though you have a defective heating element.
May 31, 2012 | Maytag Atlantis MDG7400AW Gas Dryer
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Gas dryer heats for couple minutes then goes cold
sounds like gas valve is not opening. your ignitor has to pull 3.2 to 3.6 amps to open gas valve. check amps
Jun 22, 2009 | Kenmore 63942 Dryer
Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Jun 15, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer will ignite and get hot briefly then go cold
More likely problem is your gas valve coils are bad. Very common problem. As you described, burner will fire up initially and then will no fire again the rest of the cycle. Testing the coils with a meter will not help you here. The wire inside them is as thin as a human hair and they will check"good" with a meter.
FWIW, that radiant sensor rarely fails.
Dec 13, 2008 | Dryers
Maytag MGD6400T Gas Dryer Logo
130 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
