Question about Health & Beauty
My gibson digital thermometer when on says Lo instead of showing temperature.what could be the problem?i even changed the battery.but doesnt work at all..solve plz
  • 4736 Answers
SOURCE: I replaced the battery in
This usually happens if the battery is not installed the right way. Meaning you have the + & - reversed. Also, and this happens more than you'd suspect ... the new battery, in fact may be weak..
Hope this helped you solve the problem.
Posted on Mar 16, 2011
SOURCE: Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Posted on Jan 23, 2009
  • 232 Answers
SOURCE: Batt Lo Displayed. I replaced with new batteries.
sometimes you can bend out the battery holders to allow more tention on the batteries but thats only a temporary repair. a new thermostat is needed
Posted on Oct 28, 2009
Testimonial: "Thanks! It appears that you are right--I even tried other "new"batteries....Off to buy a new thermostat."
  • 43501 Answers
SOURCE: Incorrect ambient temperature on Honeywell Model RTH221B
Check in your manual for the thermostat. By pushing a combination of buttons you can get into the advanced installer menu. From there you can make an adjustment to correct the temperature.
Posted on Nov 12, 2009
SOURCE: outside temperature thermometer on 2005 Ford Freestar van
my thermometer is blinking -40 degrees how can i fix this
Posted on Aug 01, 2010
Keep gettinG LO thermometer when taking my son's temp. but quite Ok with others
The actual temperature may be below the calibrated range of the thermometer.
Sep 22, 2016 | Braun Irt 4520 Thermoscan Ear Thermometer
What does Lo mean on a digital thermometer?
The sensor is sensing a temperature that is lower than the lowest possible temperature that can be displayed on the thermometer. If it is actually warm then the sensor has failed
Mar 02, 2015 | Lumiscope L2013 Jumbo Display Digital...
Can't get a temperature reading on my Springfield 91756 thermometer even after changing batteries. Just get - - -.
The batteries in the outdoor unit have to be changed first and time allowed for it to begin transmitting. If you are in a very cold location, the batteries may may decline in efficiency to a point where the outdoor unit can't transmit. In this case, you may find that the temperature reading returns in warmer weather.
Feb 23, 2015 | Springfield 91751 Digital Rf Weather...
Oven thermometer only displays lo
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
Dec 25, 2013 | Farberware New Classic Alert Oven Probe...
Thermostat broken?
If your oven has a dial that is used to set the temperature instead of a digital control then yes, the thermostat has gone bad and is not shutting the heat off at the appropriate time.
May 17, 2012 | Smeg S20XMF.1 Stainless Steel Electric...
The digital thermometer was flashing "lo". I assumed it needed new batteries and then replaced them. It is still flashing lo, but also showing a C reading. What do I need to do to reset it?
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
Jul 15, 2011 | Prestige Medical Infrared Ear Thermometer
When I turn on my BD Digital thermometer, it does not beep but shows as follows: 188.8, o.k., Lo and it remains in Lo. What is the problem?
you have to change the battery of your thermometer, its already weak,you need to replaced it.
Jun 22, 2011 | Baby Care
I just changed the battery and I keep getting the temperatures in Celsius instead of Fahren. How do I change it to F?
You need to discinnect the battery and reinstall it. When you reconnect the battery press the 'SET' button within 15 seconds. The temperature reading will now be set to Degrees F.
See below.
Setting/Changing ºC and ºF Temperature Scales
The food safety thermometer can display temperature in either the °C
(Celsius) or °F (Fahrenheit) scales. The desired scale is selected at the time
the battery is installed:
Selecting the °C Scale:
When the battery is connected to the battery leads the °C scale indicator
shows on the display for approximately 15 seconds. If the SET button is
not pressed the unit will time out and default to the °C or Celsius scale.
Selecting the °F Scale:
If the SET button is pressed within 15 seconds of connecting the battery to
the battery leads, the temperature scale display will toggle to the °F scale
indicator and the unit will now default to the °F or Fahrenheit scale
Feb 28, 2010 | Fluke Networks Fluke/Raytek FoodPro Plus...
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Health & Beauty Logo
243 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
