posted by CAPTKING on May 26, 2008
I have a Toshiba 32af44 TV, the picture is dark on most channels and when watching dvd or playing video games. What do you suspect is wrong? TV was manufactured in 2005.
Solution #1
posted on May 26, 2008
Hello CAPTKING,
Your TV specs as a flat screen and not a projection TV. So this diagnosis is for that of a flat screen CRT. It appears that your filament voltage might be low or the CRT cathodes have excessive oxidation on them. These are the two primary reasons for this type of failure. The secondary reasons would be low video signal, problems with the screen, focus, or control grids, or low anode voltage (which would also cause picture shrinkage). I would suggest that you take the TV to a qualified TV repair shop to have the work done.
Have them run a diagnostic on the CRT with a CRT analyzer and check the CRT voltages with the TV connected to a video analyzer set at the normal configuration for a color picture.
I hope this helps
Thank you,
Shuttle83
I hope this helps
Thank you,
Shuttle83
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Projection Televisions
Email this problem
Email this problem
This Problem Also Relates To:
Panasonic PT-47WX42 47 in. Rear Projection Television
Panasonic PT-50LC14 50 in. Rear Projection HDTV-Ready Television
Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
Panasonic PT-52LCX65 44 in. HDTV Television
Panasonic PT-43LC14 43 in. Rear Projection HDTV Television
Panasonic PT-47WX51 47 in. Rear Projection Television
Sony KP-53S70 53 in. Rear Projection Television
Can you Help with these Projection Televisions problems?
Philips 55PP9363 55 in. Rear Projection...
Phillips 55PP9363H/17
Plug in, push power button,... Answer This...
Repair Service
Find Projection TV Repairman Near You:
