Question about Cell Phones
FWT Dowtel Modem WS-8000 Antenna Signal Receive weak
  • 718 Answers
SOURCE: displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Posted on Feb 23, 2009
  • 59 Answers
SOURCE: i want the driver for huawei fwt wireless modem
I'm giving you two links to download the drivers for Huawei fwt wireless mode
1- http://www.openpages.info/huawei.html and
2- https://answers.launchpad.net/ubuntu/+source/wvdial/+question/43266
You will probably need to edit the wvdial.conf file a little so that you are using the right connection parameters for your internet service.
If those URL's did not help, please follow this procedure:
Step 1: Open Terminal from "Applications->Accessories->
Terminal"
Step 2: Run the following commands (copy-paste each line below to the Terminal then hit <enter> after each line)
ifconfig
sudo lshw -C network
lspci -nn
lsusb
uname -a
dmesg | grep USB
Step 3: Post results (cut/paste terminal output from each command) here
Step 4: Provide us with the full model and make of Huawei modem. What is the exact model number? Does it connect to the PC using a serial-to-USB converter?
Posted on Apr 19, 2009
SOURCE: problem to install huewai ETS 1201 modem driver
Problem to install huewai ETS 1201 modem driver
Posted on May 01, 2009
  • 5 Answers
SOURCE: downloading the HUAWEI FWT Wireless Modem Driver
http://webmomy.com/wp-content/uploads/2009/02/ptcl_wireless_modem_drivers_manuall.zip
Posted on Jun 01, 2009
SOURCE: Claro AlCATEL X030 HSDPA USB and a weak signal..
I want a driver for USB HSDPA X200 driver. No driver found at the alcatel site.
Posted on Apr 08, 2010
I'm having trouble getting a signal using a boost waves TV remote controlled rotating antenna. No signal
It may be too weak to receive and re-adjust external signals. Return it for refund.
Jan 04, 2015 | Toshiba Televison & Video
Tv wont tne in to ch9 why iam getting all the other channels
If you are using an antenna to receive broadcast TV you may have to rescan to add channel 9 back into the TV's channel list. If this does not work, it may be seasonal or a weak signal from your channel 9 broadcaster. I use a signal booster on my antenna (purchased at Radio Shack..)
Dec 10, 2014 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
How do I get a signal from my Jack OA8200 digital tv antenna.
The signal meter should show you available TV transmitters. If you have received a signal at this location before and you definitely are sure it is powered up the antenna is defective. Check for anything that appears loose or broken. If the meter indicates a signal check the cable that goes to the TV.
Oct 28, 2014 | Jack OA-8000 Digital TV Antenna
How do I strengthen my wireless signal? I am using a Linksys router.
The easiest is to replace the small antenna with a higher gain one. You get some very effective 8+ db gain omni directional antennas for linksys on ebay, amazon etc.
If you are in one direction you can also use a Yagi antenna (Directional) with high gain (20+db gain)
Normally the problem is not just the router, but the connecting device as well.
Keeping in mind you have 2 way comms between 2 devices. The router and say a laptop. ideally you should upgrade both antennas. As the best antenna on an Linksys AP will not fix a weak laptop signal. (it will transmit better, and receive better, but the laptop should also transmit and receive better)
Hope it helps
Wilhelm
Mar 29, 2011 | Linksys Wireless-G Broadband Router
I bought HDTV/UHF/VHF/FM INDOOR PASSIVE ANTENNA please help me to install it it is not working
Is the antenna the correct one for your environment? Do you have the antenna pointed at the stations you want to receive? Use antennaweb.org or tvfool.com to get an idea of the location and likely channels you can receive at your location. Antennaweb assumes an outdoor antenna but is very conservative in the list of channels you can receive. (These may match the limits of the indoor antenna.) TVfool lists the stations and the appropriate antenna that will likely receive each station.
Tall trees and buildings will block the signal. Get the antenna as high as possible. Move the rabbit ears and UHF loop to maximize your signal strength. Then make sure the TV is set to use the OTA tuner (ATSC for digtal stations). (That may mean changing the source in the setup menu.)
Then scan for channels. Move your antenna or parts of it and rescan or edit the channel list. (For some TVs there is a weak signal setup option that will let you manually enter the station number (including sub-channel). Then it will provide the signal strength information as you move your antenna.)
I hope this helps. An amplifier may help you bring in weak stations with enough signal strength for the tv to see them.
Jan 19, 2011 | Philips Televison & Video
Downloading the HUAWEI FWT Wireless Modem Driver
Apr 26, 2009 | Computers & Internet
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
Mar 26, 2009 | Computers & Internet
No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
biigg53566
Feb 19, 2009 | Insignia Digital-to-Analog Converter for...
Modem driver for Huawei FWT Wireless Modem
.Sir ,
I am having Huawei FWT Wireless Modem..For Internet connection(dail up).
Very slow working .Please solve my problem..
Aug 19, 2008 | Computers & Internet
Cell Phones Logo
156 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
