Question about Garden
I have a 1977 sears 18/6 garden tractor with a onan engine 917.25191 with less than 200 hours on engine,.it is hard to start,but runs fine once started.It had been sitting in a shed for about 5 or 6 years,I took the carburetor off and let it soak in a carb solution. put it back together.it has new points and condenser,new plug wires,and plugs and is getting a good spark.I have put an electric fuel pump on the fuel circuit 1 to 1&1/2 psi.I have a filter between the fuel pump and fuel tank .All the safety switches are working good.sounds good when idle or running
If the electric fuel pump is mounted higher than the fuel tank it will have problems getting suction. Be sure that it is mounted down on the frame rail (below the fly wheel is a good spot) so that the suction side is always submerged. Otherwise the pump will take awile to supply gas to the carb bowl. It may get it eventually, but it will burn itself up trying.
Posted on Dec 12, 2010
Jonhn deere 420 lawnmower starter remove
Provided it still has the orginal engine here is the service manual for the Onan Engines P48G and the P220G. Starter info start on PDF page 185 (manual page 60-1)
Onan 16 18 20 24 Service Manual pdf
Aug 25, 2014 | Garden
Kohler 26 No Compression on one side
hey your lucky my head gasket blew at 41 hours wasn't hard to due but its the point of having low hours that bothered me
Apr 27, 2012 | Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
I have a 1989 Sears Craftsman 20 HP garden tractor with an Onan engine. It will run for a few minutes and then just stalls out like it is not getting any gas. I wait a couple of minutes and it will start...
Try this:
The next time it begins to stall, loosen the gas cap.
If the engine runs smoothly, you have to clear the vent holes in the fuel cap.
Gary
May 04, 2011 | Garden
Deere 318 with Onan B43G won't start w/ starter engaged, but if the engine "catches" when I turn off igniton, it runs fine. I can only get it to start by pulsing the starter on and off--only starts when...
318's are known to have flywheel problems and poor engagement of the starter due to incorrect alignment of the starter to the ring gear.To check either of these things you need to take the motor out of the tractor to look at the ring gear,starter drive and starter aliggnment.Before you go through this pain replace the ignition switch or have it tested.p.s deere only supplies a replacement flywheel but a ring gear can be ordered through a case dealer if you get it for a stinner with the onan engine.
Nov 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Is there a way to test the ignition condensor on an 18 hp onan engine in a 318 John deere lawn tractor.
not worthtesting just replace it if its suspect as they are only cheap to buy & easy to fit
Jul 25, 2009 | Garden
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
282 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
