Question about Keurig B60 Coffee Maker
Keurig will not power on - Keurig B60 Coffee Maker
I have a Keurig 2.0 when you plug it in the power button comes on, on the lcd screen but when you touch the power button nothing happens. It won't turn on. Any suggestions. Thank you.
Found the below from this site: http://coffeestylish.com/keurig-problems/
Keurig 2.0 won't turn on
To turn on your Keurig 2.0 plug in the brewer, then press and hold the power button (the power icon will appear in the bottom right corner of the touchscreen). You should see a welcome! note. If it doesn't turn on you can do few things:
Check to make sure that the brewer is plugged securely.
Unplug and plug in the brewer.
Plug the brewer into a different outlet.
As a last step, Keurig even recommends resetting your home's circuit breaker just in case.
If nothing works, then you should definitely call Keurig customer service.
Jan 24, 2016 | Computers & Internet
How do I fix my Keurig B60 SN#65.0100.3601827 power won't turn on?
It sounds like your power is off. all should be fine when it is restored.
Jan 27, 2015 | Keurig B60 Coffee Maker
KEURIG B60 COFFEE MAKER
If no power, the circuit board is defecetive, return for a replacement.
May 28, 2012 | Keurig B60 Coffee Maker
Platinum keurig no power
under the warranty they mist give you a new one
Apr 10, 2012 | Keurig Platinum B70 Coffee Maker
Keurig B66 model - "Not Ready" message when I push
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101-=-=-
May 31, 2011 | Keurig B66 3-Cup Coffee Maker
My keurig won't turn on when I push power.
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
Dec 13, 2010 | Keurig B60 Coffee Maker
My Keurig is dead- no power
heatman101
Nov 25, 2010 | Keurig B100 Coffee Maker
I am not getting power to keurig
heatman101
Nov 15, 2010 | Keurig B100 Coffee Maker
Had the keurig 1 year.. This morning no power on keurig why?
heatman101
Nov 07, 2010 | Keurig Ultra In Home Single Cup Brewer...
Keurig B60 Coffee Maker Logo
1,088 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
