Is Windows xp professional version 2002 service pack 2 is not xp home service pack 2. is this compatible with sql server 2005? Thanks
If someone need windows key can go site www.vinhugo.com to got. My key got here and after i used is great works. Hope it help you.
Posted on Jun 02, 2016
    President:
  • 2,340 Answers
All Service Pack 1, 2 or 3 for XPs are for Pro & Home Edition and are not meant for other Windows Version!!
As for SQL Server 2005 you can get your Latest Updates & Service Packs @ http://support.microsoft.com/kb/913089
Hope it helps.
Posted on Oct 02, 2010
Forgot SQL Server SA password. How to reset user password to login SQL Server?
When SA password for SQL Server logon forgot, please take SQL Password Genius to install it on computer.
Step 1: Run SQL Password Genius full version and browse Master.mdf file to import into it.
Step 2: Select SA user and click "Reset" button.
After master database file imported into SQL Password Genius, you would see all user in list. SA password is unknown. Select SA account and click "Reset" button.
A new window would pop up, type new password for SA account in it. And click "OK". Instantly, SA password is changed successfully. SA password lists in software screen.
Step 3: Close SQL Password Genius and restart SQL Server Services.
SQL Server services influence SQL password reset on computer. So we stop it before using SQL Password Genius. Now, when you finish SQL SA password reset, restart SQL Server Services to run SQL Server with SA account.
How to Reset SA and Other User Passwords for SQL Server
Jun 27, 2014 | Microsoft SQL Server 2005 Enterprise...
Tip
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
How to recover SQL server mdf files?
RecoveryFix for SQL database recovery software is recover and repair MDF files components from corrupted SQL server database. This software compatible with Windows 7, Server 2008, Vista, Server 2003, XP and 2000. More details see this site: http://www.en.repairsqlserver.net/ or download this tool from http://www.en.repairsqlserver.net/free-trial.html
May 06, 2014 | Microsoft Database Software A5K-02817 SQL...
I forgot my sql server password, and i need to get the sql sa password back, how can i retrieve my sql sa password? its SQL server 2005. Any advice is ok, i dont want to reinstall the SQL server, Thanks in...
Lost or forgot your administrator/user password for Microsoft SQL Server?
If so, turn to help from AnyPasskey SQL Password Recovery, which is a professional program enables you reset administrator or user password for Microsoft SQL Server instantly regardless of the length, complexity, language and encoding of the password set before. As long as you got AnyPasskey SQL Password Recovery and master.mdf file, you could reset SA password on any authorized PC in minutes without the installation of Microsoft SQL Server. What's more, this featured-in tool supports all versions of Microsoft SQL Server and Microsoft SQL Server Express perfectly. 6_21_2012_1_55_07_am.jpg
Sep 15, 2010 | Computers & Internet
I can't install the service pack 3 of SQL server
Are you installing SP3 for SQL 2005 Standard or Express editions?
According to Microsoft, the standard edition will not work on XP Home.
See:
http://technet.microsoft.com/en-us/library/ms143506(SQL.90).aspx
Aug 01, 2010 | Microsoft Windows XP Home Edition
My os is Windows xp Professional version 2002.I can't install ms Office 2007 the message is "need new version of your windows". what should I do without reinstal my windows? thanks
Install XP Service Pack 3 and try again.
Link:-http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e
May 20, 2010 | Microsoft Windows XP Professional With...
Visual Basic and SQL
Visual Basic 6.0 and MS Sql server 7 or 2000 are highly compatible with each other. VB.net is compatable with sql 2005 which is inbuilt as well.
Jul 07, 2009 | Microsoft Windows Vista Ultimate Edition
Unable to add local server with SQL-Server Management Studio 2005
ok, you installed the management studio but did you install SQL server?
That is not part of the management product.
Jan 03, 2009 | Microsoft Windows XP Professional With...
Unable to create database from within VWD 2005 Express
try to complete uninstall .net framework and install it again or get the latest copy of .net framework to install 3.5 latest version already available for download
Dec 01, 2008 | Computers & Internet
Which Service Pack is included with my Win XP Home Edition Version 2002?
Windows XP Home 2002 is Service Pack 1 only:
Buy a newer version.
Do not forget to rate the solution.
Many thanks.
Aug 29, 2008 | Microsoft Windows Xp Home Edition Sp2...
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
