Question about Ricoh Priport VT6000 Copier
Error E02 on Ricoh Priport JP1215 duplicator, what does it mean please?
  • aluma michael Sep 27, 2011
    what does it mean?
5 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Posted on May 07, 2010
Testimonial: "Thank you. You'd think you'd be able to search for this answer on Panasonic's Industrial site, but I couldn't even find the model number let alone the error code. Thanks for your help. "
  • 86 Answers
SOURCE: Ricoh priport jp1210
Press Clear mode > 1 0 7 > and press and hold the Stop button for 3 seconds.
Good luck and please rate me, thanks.
Posted on Jan 22, 2009
newport74
  • 58 Answers
SOURCE: paper jam message, remove the paper from drum
Try cleaning the feed rollers with soap and water and a damp cloth and see if your situation improves. sounds like the machine is missfeeding but your description was a little vague.
If it does improve youll need new rollers.
Also try flipping the paper over to see if improves.
Lastly does the paper size displayed on the screen match what is actually loaded? if not... correct as nessesary
Good luck
Posted on Apr 19, 2010
joel_baleta
  • 155 Answers
SOURCE: I have a Ricoh Priport VT2250 duplicator. I keep getting an error
ls lt an image problem? image problem can be occurred if the solid black part of the image is on top. try to reverse the image by scanning it invert the image on the other side meaning the solid part be placed at the bottom.
Posted on May 27, 2010
Testimonial: "Thank you Joel. I have tried that. When the paper is taken into the machine, it will make two copies and then lower the paper tray and say jam. I have tried everything. Any other ideas? "
What does error code E-06 mean on a ricoh priport duplicator mean?
It's a main motor error. Check the sensors at the back when you remove the drum. Check to see if the sensors are in place.
Jan 21, 2015 | Ricoh Office Equipment & Supplies
Ricoh priport vt 3800
when it print remove some of letter
Jun 11, 2013 | Office Equipment & Supplies
Ricoh priport jp 1010 error code E 02 explain this code to me.
when powering on, ricoh priport jp 1050 indicated 02
pls help how can solv
Jun 10, 2011 | Ricoh Office Equipment & Supplies
Ricoh DX4640PD priport machine with SC556 code - what is this, I can't get past it to open the drum unit or anything? Thanks
And how about error code SC553?i try log in test mode and use program clear mermory.the machine still code SC553
Apr 04, 2011 | Ricoh Priport VT6000 Copier
May 26, 2010 | Ricoh Priport VT6000 Copier
Error message E02
Ricoh Priport VT-2100/2130/2150/2300/2500/6000
E 01 Malfunction in cutter section: The cutter motor does not reach both right and left cutter position detecting switches within 2 seconds 1) Drive wire cut
2) Drive section malfunction
3) No power supply E 02 Malfunction in the paper table drive section: The lower limit sensor or the paper table height sensor is not turned off even though the paper table UP or Down signal is applied 1) Drive worm gear broken
2) Mounting screw of the worm gear broken
3) No power supply
Apr 01, 2010 | Ricoh Priport VT6000 Copier
Paper Sticking to the drum
Check in what condition separators drum.
Sep 06, 2009 | Riso RZ220 Duplicator
Dec 21, 2008 | Ricoh Priport VT6000 Copier
748 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
