Question about Amana ARB220RCW Bottom Freezer Refrigerator
Refrigerator only going on for a few min. a day. Freezer cold, lights on, warm refrigerator. hearing popping and cracking noises from back of fridge.
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Hotpoint Fridge Freezer makes a lough cracking / popping nose
think the door was left cracked open all day while we were at work, so it had to work to keep cold all day- and now it's making this horrible noise and not really cold as it should be. the noise is coming from the back, there are a few things that could be causing the problem. If the unit seems louder when the compressor starts, it's probably a normal sound. The compressor starts with a high pressure, but as the pressure balances, the noise should become normalized. The compressor is in a black case with no visible moving parts. It's located at the back of the refrigerator near the bottom and has wires and a bunch of tubes going to it. If it's humming, or making a steady noise, and your refrigerator is still not cooling properly, there could be a problem with one or more various components. If the compressor is making noise, there's probably no repairing it. You'll have to replace it. This is often a very costly job and needs to be done by someone with the necessary EPA certification to work on sealed systems.
Dec 19, 2013 | Hotpoint Refrigerators
Jen air jcd2289aew freezer working but almost no cold air blowing into fridge
You should not be hearing any popping noise from the refrigerator. That could indicate a defective start relay or attached wiring. Can you tell me the freezer temperature? After the refrigerator has run for a while I need you to remove the rear panel in the back of the freezer. Unplug first and quickly remove the panel and tell me what the frost pattern looks like. Reason I ask is I need to make sure that there is no Freon loss. If there is loss of Freon the evaporator will look like this in photo HERE This problem could also be a defective auto damper in fresh food compartment not allowing cold air from the freezer side. Here is a link to a Service Manual HERE Try these things and let me know what you find. I am here to help you get this refrigerator going, Thanks Sea Breeze
Mar 11, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Fridge and freezer warm. Mildly cooler air is coming out but the settings are on 7 for both fridge and freezer which are the coldest. Hard to tell if its actually cooler air or just seems that way because...
heatman101
Jun 02, 2011 | Maytag MFD2560HES Bottom Freezer French...
Hi - My refrigerator has begun making a very loud noise - like an airplane engine - when it kicks on. After a few minutes the sound recedes but is still louder than normal. The bottom freezer is way too...
it sounds like ice built up arounnd the fan blade probably from leaving the bottom freezer door open and warm air got in and froze up the air ducts or you have a defrost problem but if you hear a cracking sound it sounds like the heater is coming on but can't melt out all the ice.try this,take out all the food out of the freezer,unplug it,get a hair dryer and blow the hot air at the back wall where the vent holes are and melt out all the ice,when you look into the vent holes and don't see anymore water dripping down you can plug it back in and with your hand feel to see if you can feel the air blowing into the fridge section,if you feel the air then you melted out the ice and if the noise is gone then the evap fan motor is still good,if there's alot of ice and snow on the back wall you should remove the panel and then melt out all the ice with the hair dryer.also if you have another fridge you can unplug the fridge and let it melt out on it's own for like a day
Feb 10, 2011 | Refrigerators
Our refrigerator is intermittently warming up (up to 37 degrees in the freezer & 64 degrees in the fridge) and then cooling down again. There is a clicking noise that has gotten more persistent. The...
heatman101
Oct 28, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator very warm and won't cool , freezer working but...
if the compressor wsnt running it wouldnt get cold the real question is is there ice in the freezer on the back wall
Jun 02, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Amana ARB220RCW Bottom Freezer Refrigerator Logo
134 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
