Question about ASUS W1N (W1NCOMBO) Barebone
Asus W1N notebook ram upgrade
Cannot locate factory installed ram, suppose to be under the key board.
  • matimatic Jan 25, 2009
    i have the same blem
  • john F K Apr 18, 2009
    Found 1 module under the cover on the bottom. Other 512 module I cant find. Is it integrated on the mainboard? Anyone?
  • 43 Answers
Try looking for a small hatch that has a screw holding it in. Should be on the back
Posted on May 28, 2008
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Hi, my Asus a8m has 512 mb of ram. I'm considering buying a macbook, but wondering if it would be worth upgrading to 1 or 2 mb of ram and having a professional 'clean out' my asus. Would it be worth it?...
max supported memory is 2GB (2x1GB sticks replacing your current memory). Yes, it'd be worth it to add more memory of you were keeping the machine, otherwise restore it to original configuration and sell it "as is". Don't get a professional, just used your ASUSes restore option to set it back to factory configuration.
Feb 07, 2010 | ASUS A8M Notebook
Upgrade affect warranty?
A ram upgrade will not affect your warranty. The RAM is one of the items that the manufacture allows the user to replace. You are good to go.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 09, 2009 | ASUS Computers & Internet
Asus 1000 freezes after 2g ram upgrade
Go into bios and make sure mem is set to auto find ,might help
Feb 24, 2009 | ASUS Eee PC 1000 Notebook
My computer cant start up and is making a beeping noise
Most likely a ram problem. Sometimes reseating the memory will fix the problem.
Remove and reseat the RAM On most notebook PCs, removing and reinserting the memory is a simple step and does not require advanced technical knowledge of the computer. HP recommends reseating the memory module before arranging for warranty service repair. If you are not confident following the steps for removing and replacing the memory module in this document, contact an HP support specialist for assistance.
NOTE: If someone other than HP installs or upgrades the RAM, any damage caused by the RAM and/or by the person when trying to install or upgrade the RAM is excluded from coverage under the product warranty. The customer assumes all risk and liability for damages for any such installation or upgrade.Some HP notebooks may have a secondary memory module located under the keyboard. For removal and replacement instructions pertaining to the second memory module contact an HP support specialist for assistance. WARNING: This product contains components that are easily damaged by Electrostatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, set the notebook on a grounded surface that dissipates any static charge, and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC. Use the following steps to remove and replace the memory modules. These steps should be repeated for each memory module installed in your notebook. Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
    NOTE: When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. After removing one module, replace the memory expansion cover and then replace the screw.
Step 3 - Reseat the memory module
  3. Locate the alignment slot on the memory module and align it to the empty board receptacle.
  4. Grasp the memory module by the edge and push gently to install it.
  5. Press the expansion memory board down to latch the tabs.
  6. After replacing the module, replace the memory expansion cover and then replace the screw.
After the memory is reseated, connect the AC adapter and turn on the notebook.
Nov 10, 2008 | HP Pavilion dv6000z Notebook
Where is the expansion slot for the RAM for ASUS Notebook A2400H?
The manual is incorrect. Memory is under keyboard. There is a small hole to the left of the right speaker. insert a paperclip vertically into the hole and apply a slight amount of pressure at the same time sliding the plastic section to the left. It should be obvious at this stage. then fold back keyboard. 2 memory slots are located under the plate near the middle of the unit. Specs say max of 2 x 512MB modules. they are PC2100 DDR266 200 pin SODIMM. If there is someone else reading this maybe they can tell me what the slot is for under the smaller plate to the right of the memory compartment.
Aug 06, 2008 | ASUS A2H (A2HOB) Barebone
RAM Support
Please post the model number of you're Gigabyte board. This is key in order to answer you're question. The model number can be found on the board, if not written in bold white lettering on the board it will be found on one of the PCI (white) slots.
Apr 16, 2008 | AMD Sempron 2500 CPU (Box) and Motherboard...
ASUS Ram Location
look in the manual on page 16.shows where its located.
Apr 04, 2008 | ASUS A2400H Notebook
RAM upgrade for Asus AR9p notebook.
ASUS has a great website and it will have the directions listed under the model of your system. They have everything that you will ever need there.
Rate me as FIXYA if this helps.
Apr 03, 2008 | ASUS m6n Notebook
Asus M2N-MX Motherboard 4gb Ram wont work
I had the same problem and ASUS tech support was of no help. I did however find the culpret in the BIOS setup. Go to Advanced, Chipset, NorthBridge Chipset, and Memory Configuration. Set the Bank Interleaving to Disabled and save the settings. Check these settings also while you are there:
Channel Interleaving = Auto
Enable clock to all DIMMS = Disabled
Memory Tristate = Disabled
Memory Hole = Enabled
Unganged Mode = Enabled
Power Down Enable = Enabled
Power Down Mode = Channel
By Wayne F
Dec 19, 2007 | ASUS M2N-MX Motherboard
ASUS W1N (W1NCOMBO) Barebone Logo
345 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
