Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune breakdown
I have a 6 yr old maytag neptune dryer, it doesn't put out heat. I checked the voltage, 240 all the way. I found a broken ground wire at the heating coil, fixed that. Still no heat. What els can be wrong?
  • Degaul Yang May 29, 2008
    Dave,
    I was able to find the problem, it was a bad thermostat.
    Thanks,
    Degaul
  • Anonymous May 30, 2008
    where is the thermostat located
  • 525 Answers
Warning! Shock Hazard! Disconnect dryer from power source before servicing.
I assume you repaired a wire that attaches to a white ceramic insulator terminal? If you have a volt-ohm meter, you can check continuity of the element and hi-limit thermostat and overtemp.fuse located on the element shroud. If you ddon't have access to a meter then visually inspect the element for a break in the coil. The fuse and hi-limit can be temporarily bypassed 1 at a time to eliminate 1 or the other being faulty. Also double check your heat temperature settings on the control panel to make sure it did not become de-selected. There are also temperature control thermostats attached to the blower housing in lower left corner of the dryer that can be temporarily bypassed to test for failure. Tip: Clean lint filter after each load. Clean vent to outside,(check every 3-6 months), and refrain from overloading dryer. This will help extend the life span of the element and the dryer itself.
Hope this helps!
Posted on May 27, 2008
  • David Emmel
    David Emmel May 29, 2008
    Just checking back to see if you need any further assistance.
    Contact me if you do.
    Thank you,
    Dave E (Illeagle)
  • David Emmel
    Thank you for your very generous rating!
    If I can be of assistance in the fture just give me a rattle, I'll be more than glad to help.
    Dave E (Illeagle)
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Tip
My maytag neptune dryer would not warm up
My 2 yr old Maytag dryer took forever to heat up. called the repairman and I found out that when the company I bought the dryer from installed it they kinked the duct hose. Solenoid was replaced but burnt out since the duct when obtructed. You might want to pull the dryer out and check the hose.
on Jul 06, 2008 | Maytag Neptune MDG5500AW Gas Dryer
The voltage in my country is 230volts 50HZ I have a 120/240 volts maytag dryer what can i do to get it working
Normally the 240 volts rating is nominal and the device will run at 230 volts. The question is will the dryer run at 50 HZ? Check on the electrical rating tag on the machine. It may work. The motor may just spin at 50/60, 5/6 of the 60 HZ speed.
Gary
Aug 31, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is not heating,we have checked all of the settings, and the barrel is spinning so can you please help, the unit is about 4 yrs.old I have a maytag neptune
check ur breaker first, dryers will run on 120volts but wont heat unless have 240.
if electric check ur heating element, thermostats, and thermal fuse for continuity with a meter.
if gas check the ignitor,thermal fuse, and secondary gas coils,
Feb 05, 2010 | Maytag Dryers
My maytag neptune eletric dryer is not drying my cloths only cold air circulates. checked continuity of heat element,good, no limits or fuses open, 120volts to each side of the element. What am i missing?
Should have 240 volts at element.  If it has continuity, you will read the same voltage on either side.  Check across the element for 240.  If you only have 120 check for 240 across the two outside terminals where the cord hooks up.  More than likely either a half tripped breaker or defective breaker.
Dec 19, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Apr 07, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer performing inconsistantly
you either need a new heating element or you are not getting full 240 volts, im assuming its electric here. check your outlet to make sure both leads are hot.
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
The heater and timer do not work
The timer won't advance unless te clothes are drying with heat.(No heat, no movement).
Check your fuse or breaker box to see if you have a tripped 30 amp breaker,(Flip breaker OFF then back ON), or blown 30 amp fuse.(Replace both 30 amp fuses to eliminate the possibility of being wrong).
If these check ok,(be certain), then you have a breakdown on the heat side of the 240 volt circuit, at which point, I would recommend calling a technician.
Let me know if I can be of any more assistance.
May 26, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
176 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
