My computer keyboard does not work i am told its a hardware problem can you diagnose and repair?
  • 573 Answers
Open the Control Panel>Regional Options my computer keyboard does not - 6a8a6d0.jpg
Click on the "Customize" button next to the first pull down menu. Sometimes these settings can interfere with your keyboard. Make sure that, at the bottom of the "Customize" dialogue, your measurement system is set to whatever system your region uses. Once that tab in "Customize" is all set, move over to "Currency," "Time," and "Date," making sure that their settings are correct. Click "Apply" for both the Customize window and the Regional and Language Settings window. Test out the keys using a word processing program such as Notepad or MS Word. If the problem persists, it may be a hardware issue. And if the above steps didn't work then your keyboard may be broken. Take a screw driver, cotton, and "spirit or aciton" and eraser "rubber". And then open or untie the screw of your keyboard and slowly remove all the keys and try to remove the carbon and gently wipe out all the keys attachment by applying the spirit and wipe out with cotton or rubber "eraser" gently where there is dirt. Then Check out whether there is disconnection or not?. And fix it as before and tied up all the screw it and fit in your CPU and see whether it's working or not if not my comment is to buy "purchase" a new one.
All the Best!
Posted on Oct 02, 2010
Hi - my Acer PC has suddenly stopped working with it's keyboard. The keyboard works fine with other computers and I have tried other keyboards with this computer and they fail. It is as if the driver is...
Hi.
Try this:
1. Right Click on My Computer
2. Choose Properties
3. Device Manager
4. Delete all the hardware which appears under keyboard.
5. Reboot computer
6. Connect Keyboard.
Hope this helps.
God Bless You!!
Feb 05, 2011 | Acer Aspire One PC Notebook
Tip
Computer Repair Services
Computer repair includes software and hardware repair. Hardware repair is needed when any part of the computer is not functioning as expected. Software repair is required when any software program is not executing properly.
Need of computer repair
Computer repair is needed for making your computer function properly. Your computer will function properly if all its parts are working properly. Some of the issues for which you require computer repair are as follows:
• Computer automatically shuts down
• Computer takes much time in launching applications
• Computer system crashes or locks up
• Blue screen error
• Computer makes beeping sound when switched on
The reason for most of the computer issues is the lack of maintenance. For maintaining your computer and optimizing its performance, you have to update software regularly, clean registry, empty cache files and many others.
In case, you have the knowledge about how to repair your computer, you can perform it yourself. But if you do not have any knowledge in this field, then you can contact a computer support technician.
Computer repair technician is a person who will repair your computer either through online or on-site. Online computer repair is preferred in case your computer needs software repair. If you want to go for online computer repair, all you need to have is an Internet connection. Online computer repair saves your from the pain of taking your computer to some technical services center or inviting some technician at your own residence.
These days most of the companies offering online computer repair adopt the method of remote desktop connection. Technician will access your computer with the use of software made for remote desktop connection. But you have to give him permission for doing so. After getting permission, he will diagnose your problem and after that resolve it. Technician will install, reinstall or uninstall any software, or modify some of the settings for resolving issues.
In case of hardware repair, you have to call a technician in your premises. Technician will diagnose all of your peripheral devices, in case of any faulty one, he will replace that one. He will also update drivers of peripheral devices.
So, it can be said that computer repair is required when your computer is not functioning as expected.
on Feb 04, 2010 | Computers & Internet
Windows XP loads up but when prompted to click user, mouse will not work, I have tried 2 different mice confirmed to work on another PC, keyboard then locks up when press any key, tried to repair with xp...
try blowing out all of the dust from your laptop keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you should see driver details,you will have options to update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
as for the mouse
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options also hardware under hardware you can troubleshoot or
select properties under driver you will have the options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 22, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
M-Audio KeyStudio is connected using the USB cable and the keyboard is turned on, but I get the message NOT CONNECTED. And, Pro Tools M-Powered Essential (ver. 8.02) says that it is Unable to find a...
Soltion is to download the software for Micro USB from M-Audio website and connect the USB of the Micro USB to your computer with headphones and mic connected to it and connect the USB cable from the M-Audio KeyStudio keyboard to the computer and the Pro Tools M-Powered Essential software will work.
Jan 28, 2010 | M-Audio Computers & Internet
The system would lock up after going into sleep
Try Hard reset remove all the peripherial and power supply connected to the Computer Tower No Mouse, No Keyboard, No Ethernet cable and usb device should connected to the Tower and then press and hold down the power button for 30seconds and then connect only mouse keyboard and power supply to the Tower it should resolve the issue if it will not than set up bench repair this is Hardware issue.
Thanks and Regards
Neeraj Sharma
Oct 16, 2009 | HP Pavilion m7560n PC Desktop
HI MY KEYBOARD IS NOT WORKING ONLY SOME KEYS, THE I, K,O , COMA ARE NOT WOKING, ANY HINTS, THANKS
Hi eustaquio_ma,
There is no other option either then replacing the keyboard. This is internal circuit problem.
Thanks
Smith
Jul 15, 2009 | Fujitsu LifeBook T4210 Tablet PC
Iphone bottom keys of keyboard don't work
ususally it's a dead strip on the iphone screen and it needs to be replaced. there is an iphone repair manual that will guide you through the steps the part is readily available on ebay.
Apr 27, 2009 | Apple iPhone Smartphone
Keyboard Reset?
try To download the latest drivers for the keyboard that you are using, visit the following Microsoft hardware Web site:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
If the issue occurs again, connect the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
good luck :)
Oct 04, 2008 | Microsoft Multimedia Optical...
Keyboard not functioning at all
The problem may be two things:
1) Its cord is disconnected from the PC unit
2) Your Keyboard drivers are outdated.
If the cord is fine, I recommend that you go to the hardware wizard (Start Menu -> Settings -> Control Panel -> Hardware Wizard) and run a "detect new hardware." This feature should be able to get your keyboard going again - and you should be able to access this feature by using your mouse only.
Aug 06, 2008 | Microsoft Natural Ergonomic 4000
I need to send my laptop back to the manufacture for hardware problems, what address? acer aspire 5610
While there are many places that repair laptops...it is important to find a company that has experience and is trustworthy.
You can search the internet and also have a look at our Depot Repair service:
http://seekpcrepair.com/service_laptop.php
Good luck to you my friend,'
SeekPCRepair
P.S. Be cautious of any company that asks for money upfront.
Feb 09, 2008 | Acer Aspire 5610 Notebook
Computers & Internet Logo
David Payne
David Payne
