Question about Foxconn Motherboard Mcp61pm2ma-8krs2hv (0683562101899)
Need wire color codes for front panel LED HDD; LED ON; and POWER SWITCH
bluegreenash
  • 661 Answers
SOURCE: Front Panel Connector
There should be a Front panel block on the motherboard
you should connect to it like this
Posted on Nov 15, 2007
map9966
  • 2351 Answers
SOURCE: i need to know how to hook up some mother board wires
Hi swiftty6, you can download the manual for this board from this link. http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=558
Than go to pg. 2-18 for a better picture showing these case connections.
Like this.
4b15236.jpg Enjoy!
Mike
Posted on Apr 04, 2008
kigwa2008
  • 68 Answers
SOURCE: PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Posted on Jul 25, 2008
charcois
  • 763 Answers
SOURCE: Gigabyte GA-8INXP Motherboard Problem- front connector pins
try to look on the wires of the casing. you can see the names on it of each wires.
PWR LED are the light on the case of your cpu(steady light)
+HD- is led light of hardisk.
+PW- is the switch of you power button.
+RES- is the switch of your reset button.
+SPEAK- speaker of your computer that is located on the front of your casing. it has a hole on it so that you just can insert a speaker with a rc jack aside from the rear casing of your speaker.
CHARCOIS
Posted on Sep 19, 2008
rockitman187
  • 2559 Answers
SOURCE: case front panel to motherboard wiring
Here is a link to the motherboard manual
And here is the hook up
Posted on Jun 03, 2009
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
MSI 760gm-p21(fx) MB, JFP1 AND JFP2 PINOUTS I NEED TO SEE A DIAGRAM SHOWING ME EXACTLY WHERE TO PLUG the cables on the MB
http://www.msi.com/product/mb/760GM-P21--FX-.html
Hover your mouse cursor on the Download tab.
(Overview/ Specification/ Download/ Support/ Where to Buy)
In the drop down list click on - Manual
On this page under the subheading Download, click on the blue -
M7641v3.0.zip
On the next page click on the country name nearest yours.
Motherboard User Manual.
This is a Zip file. If you do not know how to open a Zip file, please state in a Comment, and I will guide you.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is divided into two headers on the motherboard.
This you have stated, JFP1 and JFP2.
(Junction Front Panel 1, and Junction Front Panel 2)
JFP1 is for the Power On switch, HarDDrive activity LED, Reset Switch, and a two wire Power On LED.
JFP2 is for an internal speaker/buzzer, and a three wire Power On LED. (Dual color)
JFP1:
4 pins across the Top row.
5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is reserved for the factory to use.
D) Pins 2 and 4 are for a two wire Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO pin 10.
JFP2:
3 pins across the Bottom row.
Starting on the LEFT side coming across to the Right, Top row;
Pins 1, 3, and 5. There is NO pin 7.
A) Pins 1, 3 and 5 are for a dual color Power On LED.
Pin 1 is for the Negative ( - ) wire.
Pin 2 is for a Yellow, or Orange part of the dual color Power On LED.
Pin 3 is for a Green part of a dual color Power On LED.
B) Pins 2, 4, 6, and 8, are for a speaker/buzzer.
Pin 2 is for the Negative ( - ) wire of a speaker.
Pin 8 is for the Positive ( + ) wire of a speaker.
Pin 4 is for the Positive ( + ) wire of a buzzer.
Pin 6 is for the Negative ( - ) wire of a buzzer.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 28, 2012 | MSI Computers & Internet
I am looking for MCP61PM-HM (Nettle) 9 pin front panel power header diagram
This motherboard Adam?
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
Can't help you.
OH, I'm just KIDDING!
The area of pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
On the motherboard the Front Panel header is marked as PANEL1.
Scroll the page down, until you come to Motherboard layout.
Click on the + sign to the left of it.
Shows an illustration of the motherboard.
Bottom/Right corner is PANEL1. The black rectangle that is sitting vertically, in the motherboard photo.
Motherboard installed in computer case, the Front Panel header is two columns of contact pins.
FOUR on the Right side, FIVE on the Left side.
I don't know the actual numbering of the pins, so I'm going to number them myself;
Starting on the Left side at the Top, going down,
Starting on the Right side at the Top, going down,
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. If not, do not connect to them.
C) Pin 9 is N/C. Not Connected. It was a +5 Volt power for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
If the Power On LED is dim when the computer is on, switch the wires around.
F) NO pin 10, just a blank spot.
How to find out what wires are what, in that Front Panel harness connector?
Follow the wires from the connector, up to the Front Panel.
Front Panel removed it is easier to see where the wires go.
You can follow the color code of the wires, and see which twisted pair go up to the Power On switch.
You can also see which ones go to the Power On LED.
(Light Emitting Diode, so it is a light)
Reset switch, (IF there is one), same thing.
The only pair of wires that will be left is the HDD LED wires.
The 9-pin plug will have to be CAREFULLY cut apart. Separate the wires, AND their metal terminals. (WATCH your fingers!)
Regards,
joecoolvette
Jul 04, 2012 | Gateway MCP61PM-GM (4006254R) Motherboard
How do i plug the leds in Gigabyte GAP67AD3B3?
Motherboard installed in computer case; Processor to the TOP,
Ram Memory slots to the RIGHT, long PCI slots to the BOTTOM, the Front Panel header is at the Bottom/Right corner.
Two rows of pins, may have F_PANEL silkscreened next to it on the motherboard.
The TOP row of pins is numbered EVEN.
From the LEFT side of the motherboard, going towards the RIGHT side, across the top row of pins;
Pins 2, 4, 6, 8, (NO pin 10, NO pin 12), 14, 16, 18, and 20
The BOTTOM row is numbered ODD.
From the LEFT side of the motherboard, going towards the RIGHT side, across the Bottom row of pins;
1, 3, 5, 7, 9, 11, (NO pin 13), 15, 17, and 19.
A) Pins 2 and 4 are for the Power On LED.
IF, the LED is dim when the computer is on, switch the wires around.
These pins are used for a Power On LED, that has TWO wires.
It is a single color LED.
B) Pins 6 and 8 are for the Power On Switch.
C) Pins 14, 16, 18, and 20, are for the internal speaker. The speaker used for BIOS Beep Codes.
Pin 14 is for the Positive ( + ) wire. Pin 20 is for the Negative ( - ) wire.
D) Pins 1 and 3 are for the HarDDrive activity LED.
If the HDD LED is dim when the harddrive is operating, (Active), switch the wires around.
E) Pins 5 and 7 are for a Reset Switch, IF a Reset switch is used.
F) Pins 9 and 11 are used for a Chassis Intrusion Switch.
G) Pins 15, 17, and 19 are used for a Power On LED.
These pins are used for a Power On LED that has THREE wires.
For a Power On LED that is dual color.
Regards,
joecoolvette
Jun 27, 2012 | Gigabyte GAP67AD3B3 Motherboard Intel Core...
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
I have purchased a Thermaltake V3 black case and am trying to install my M2N68-LA motherboard. The motherboard has a combined 9 pin header for power switch, power l.e.d. and hdd l.e.d. which was one plug...
1) The 9-pin header you are referring to, is the Front Panel header.
(Processor to the top, Ram Memory slots to the right, the Front Panel header is at the bottom right corner on the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00906129&lc=en&cc=de&dlc=&product=3397528
The plastic piece on the front of your computer is the Front Panel.
(Sometimes referred to as a Bezel)
Make a drawing, and notes as to where the individual wires go from that Front Panel header plug, (One-piece plug), to the Front Panel.
Follow the wires from the plug to the Front Panel.
Mark down where Each wire goes.
You may have to take components off of the Front Panel, in order to see exactly where Each wire goes.
For example:
You may have to remove the Power On button/switch assembly from the Front Panel.
It may have the Power On LED light, Power On button, (Switch), and perhaps the HarDDrive LED activity light, in this assembly.
The wires are color coded.
Generally, but not always, when two wires are used in conjunction with each other, (Example, Power On switch, or Power On LED light), the wires will be twisted together.
One wires insulation may be of a solid color, and the other wire may be white, with a stripe in the color of the solid wire.
Example: Wire with Red color, and wire twisted with it may be White, with a Red stripe.
See if these two wires go to the Power On switch.
End of example.
Follow each twisted pair of wires back down to the Front Panel header plug.
(One-piece plug)
See which socket holes the individual wires go to.
Mark it down in your drawing, and notes.
Mark where the individual socket holes plug onto each pin, in that Front Panel header. (9-pin header)
When you are finished, you will have a pinout for the Front Panel header on the Asus M2N68-LA motherboard, and will know where the individual wires go from your ThermalTake V3 computer case.
For the LED lights there is a Positive pin, ( + ), and a Ground pin. (Power On LED, and Harddrive activity LED, for example)
(Ground. Also referred to as the Negative pin. ( - )
This is DC Voltage)
If you have the polarity backwards, (Positive wire of the LED light is going to the Ground pin, Ground wire of the LED light is going to the Positive pin), the LED light will be dim.
(When operating)
Switch the wires around.
If you have questions, or need clarification of what I have stated above, simply state in a Comment.
(Believe upper right of your page)
Jul 01, 2010 | ASUS Computers & Internet
Pulled off front cover. three sets of wires came off. need to know where to reconnect. white/red wire HDD LED, white/green wire POWER LED, white/black wire POWER SW
Hi. You may want to check your motherboard for this wires to connect to, First, check your motherboards manual and look where the FRONT PANEL is located, then on the front panel or in the manual itself it will tell you where are those wires should be connected to. If you dont have the manual for your motherboard search it on google and do the same, and if still you coudnt find it over the internet then just look closely on your motherboard and look for the words HDD LED, POWER LED and POWER SW, usually those words or the FRONT PANEL is located on the left side bottom part of your motherboard. Hope This Helps
Jun 09, 2010 | E-Machines T3302 PC Desktop
Lookig for a manual for an fic au13 motherboard
Front Panel Block Cable Connections
f_Panel
1 3 5 7 9
2 4 6 8
1] HDD-LED (+)
2] Dual Power-LED* (+)
3] HDD-LED (+)
4] Dual Power-LED* (-)
5] Reset Switch
6] Power Switch
7] Reset Switch
8] Power Switch
9] Dual Power-LED* (**)
* Single Color Power-LED 2 or 3 pins:
1 2 3
1]Power-LED (+)
2] GND
3] GND
** Dual Power-LED:
if useing dual power LED,
Green: pin2
Yellow: pin4
otherwise, Pin2 is positive (+) Pin4 is negative (-
For future Reference you can download your manual directly from the manufacturer's website HERE
Or directly from HERE
May 30, 2009 | FIC AU13 Chameleon Motherboard
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
Case wiring
For the wires that comes in your CPU casing, mostly used for your front panels like power switch, hdd status, power led, etc. It is indicated on the pins itself so you might not be confused. there are some that comes for front panel USB. (with codes like vcc+ /- ,etc.). The best you can do is to read your Mainboard manual on where you place this pins.
Feb 25, 2009 | Avus A450-3001 Micro ATX Mid-Tower Case
Foxconn Motherboard Mcp61pm2ma-8krs2hv (0683562101899) Logo
578 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
