Question about John Deere 195HP Hydrostatic 42" Cut Riding Mower
My mower will not start. I've put new plugs with the correct gap. It is getting gas to the carb. I've replaced the fule in the tank. and it is getting clean air. I've tryed starting fluid and still nothing. It worked fine a week ago. it has 109.3 hrs, series 100, LA145
  • 27 Answers
Hello, It sounds like you are not getting any energy to coil to make a spark. Follow wiring from selinoid to coil area on engine. Make sure there are no wires that have melted or rubbed on the engine metal to wear through and ground out. I think you'll find that either the positivly charged wire going to your coils has fallen off or is grounding out. You may want to try to start the mower in the garage when it is dark out, you should be able to see a spark where the positive wire is grounding out and focus on that point. First you must rule out grounding issue before replacing coil on the engine.
Hope this helps.
Posted on Oct 02, 2010
Motor mower wont start
By tipping a 4 cycle motor on a lawn mower or any equipment, you have all the oil and gas running into the combustion chamber and sometimes the oil and WATER will get into the tank. It will need too have the spark plug removed, the engine turned over with the starter to blow the oill, gas, and water out of the cylinder(s), the plug should be either dried and gap reset, and the gas tank drained and FRESH gas put in it. Replace the spark plug prime with just a few drops of gasoline in the carburetor throat and restart and let run to dry evrything. NOTE: An oil change is recommended, too!!
Jan 14, 2014 | Garden
Ai put oil/gas mixture in tank...drained tank put correct gas and cleaned air filter..will only start after prime but only for a second
You've probably plugged the carburetor up with oil. It'll need a good cleaning with carb cleaner. If you don't know how, then I'd recommend a professional to do the job. Best of luck to you.
James
Aug 20, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a troybilt 17.5 Briggs I/C OHV that is having trouble starting, gas in the oil and when it does start it is blowing oil everywhere. what is the fix?
you will need to drain all the oil out and you will all so need to flush the fule clean the carb and that mayneed a carb kit you will need to replace the spark plug turn the motter over with the plug out that will blow the gas out and then put oil in it and a new plug allso replace the fule filter and start with new gas if want to know what made this hppen well the carb got some trash in it that let the nedel stick open and let gas run in to the crank case if you need to i can be reached at mowershop@live,com ive done this kinda work for 22 years and i see this all the time
Dec 12, 2010 | Garden
8 year old Eagle I Craftsman 6.5 starts and quits? Help!
it sounds like a gumed up carb strip the carb and clean out all the running jets with carb cleaner,,,dont go poking wire into the jets you will only distroy them,,,also check that the air cleaner is clear if its cloged up the engine cant breeth and wont rev up and it will be running very ritch as well,,,check you have good flow of fule from the fule tank,,,winter takes its toll on garden tools that are stood up most of the time
Jul 10, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Spark plug gap on snapper comicial mower. briggs and straton 6.0
if you cleaned the carb thats great however if its a carb with a fuel bowl youll have to unscrew this and clean it to they have a habit of accumulating dirt and rust from moisture after cleaning bowl fuel should flow corectly without obstruction allowing smooth running operation also spark plugs are pre gapped for your mower model no need to adjust unless you bent it or are toing a custom projet such as go cart
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Jun 14, 2009 | Garden
Can't start brisggs & Stratton 21in mower. I
Get some GUMOUT carburator cleaner GAS ADDITIVE. Put about 1/2 TEASPOON in the gas tank and about 1 tablespoon per gallon into your spare gas. The float pin is probably sticking from winter non-use. This will free it ip.
You can also remove the bowl from the carburator and spray everything to immediately dissolve the varnish. Be careful not to lose the pin spring.
Jun 13, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Will not start, has been stored for approx. 1 yr
Drain the gas out of the tank. Take carb off and clean carb. Most likely needle and seat are gummed out from gas in it.
Apr 19, 2009 | Garden
John Deere 195HP Hydrostatic 42" Cut Riding Mower Logo
360 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
