Question about Microsoft Xbox 360 Controller
My power button on my xbox 360 controller is stuck and i cant turn it on or off help!
3 Suggested Answers
SOURCE: Changes batteries and button blinks green light and wont' connect
clikc ont he button on ur xbox that looks like a bunch of arrows then turn on ur controller....this should solve it, if not e-mail me at silenthunder101@yahoo.com
Posted on Feb 15, 2009
SOURCE: xbox 360 wireless contoller won't sync with game console
I had this same problem. One day i was just playing my xbox and i noticed one of my good controllers was running low on battery so i switched the batterys and battery case out from each other. When i tried to reconnect the controllers after that they wouldnt work.I tried taping the batterys, buying new ones, unplugging everything and replugging, moving metal and wireless things, and cords and rechargeable batterys. I eventually called MS support using this number -(1800) 4MY-XBOX. At first a machine answered then i eventually got to a real person. You can ship your broken or not responding controller off and they will send you a new one. This worked fine for me.
Posted on Jun 30, 2009
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My xbox 360 wireless controller will not connect to my xbox 360 console even when i press the button that scans for the pad but it still turns on the xbox 360 when you press the middle button on the pad
Turn off both the console and the controller, then follow these steps:
  1. Turn on both the Xbox 360 Wireless Controller and the Xbox 360 console.
  2. On the console, press the connect button. (to the immediate right of the memory card slot on the console)
  3. On the controller, press the connect button. (Look on top of the controller for a small button.)
  4. The green lights that surround the Guide button on the controller and the power button on the console spin and flash when the controller is being connected to the console. After the controller is connected, a single green light illuminates on the controller and on the console to show you which quadrant the controller is connected to.
Feb 28, 2011 | Microsoft Xbox 360 Controller
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
How to setup two wireless controlers to an xbox
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
  6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
  • The controller remains connected to the Xbox console even when you turn off the Xbox console.
  • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
  • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
  • If the controller does not turn on, the batteries may have to be replaced.
Mar 22, 2010 | Microsoft Xbox 360 Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Video output on wrong setting and cant see screen
for PS3, hold the power button for at least 5 seconds or until you hear a second beep.
for Xbox 360,
Turn the console on.
Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
Sep 05, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Controller Logo
335 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
