Question about Woods Hardware & Accessories
Can't seem to figure it out. Directions are not specific enough. We set "the time now", but the white/AM, dark/PM is weird. Please help w/ directions. We need the light for chicken house. Light on 5:00 AM to 8:00 AM, off until 4:00 PM then on till 10:00 PM. Trying to recreate summer light for laying hens.Thanks.
What kind of Woods timer do you have?
Is the dial turning? The dial is the clock. And the clock needs electricity to work, just like alarm clock. If dial is not turning, the wiring is not right.
Does the manual override turn on the lights? Maybe the slider switch set to OFF? Set slider to "Timer" for timer functions to work.
Wall timer:
If you have 59017 wall timer, it has dark PM white AM. You rotate dial until correct time lines up with little triangle located on right side of center knob.
There are 48 plastic pins on dial ... when pins are moved out, the lights are off. For timer functions, set slide switch to 'Timer'
Correct wiring is needed for timer to work:
Timer black attaches to Hot wire from breaker box
Timer red attaches to wire going to Load (lights)
Timer white must attach to white Neutral (or if your box has no neutral, connect white to bare ground)
Timer green connects to bare ground
If wiring seems right but dial on front of timer is still not rotating, then reverse Timer red and Timer black and see if that sorts out problem.
If this is wrong Woods timer, please re-post question.
Posted on Oct 04, 2010
I want to set the timer to go out pm, and on am. I find the instructions very confusiing
http://waterheatertimer.org/How-to-set-timers.html
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Gene
Sep 17, 2014 | Hardware & Accessories
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 29, 2011 | Hampton Technologies Brinks Timer
I have 2 intermatic lamp & appliance programmable timers. On the package the model number says: TN811C and on the timer itself says: TN811. Anyways I have read the instructions and I can't figure out...
1. To Set Program:
Pull up one tripper
between hour marks
on the 24-hour dial
for each 1/2 hour of
ON time desired. For
example, if timer is to
be ON between 12-2
PM, all four trippers
between those times
must be pulled up.
2. To set time
of day: turn dial
clockwise with the
arrow head pointed
to the correct time.
The dark area
denotes PM and
the white area
denotes AM.
Straight out of the manual. Pull up trippers for all of the time that you want the device to run.
Rotate the time of day dial in the direction of the arrows.
The off/on dial will override the timer until it comes around to the on time again then the timer will control.
Good luck.
Gary
Dec 10, 2010 | Intermatic Hardware & Accessories
How to set time in casio calculator fx-8100
1. Press AC
2, Enter the time as a four figure number, e.g. 0530 for 5hrs and 30 minutes or 1002 for 10 hrs and 2 minutes
3. Press the PM button in the botton row IF you want the time to be in PM, otherwise not.
You can use the 24-hour clock and the PM will be automatic, thus 1802 displays as PM 6 - 02
4. Press the small ADJ/SET button in the top white row. If you press this exactly on the minute the seconds will be correct.
5. I can give more instructions, on the timer/stopwatch functions (T/S) and the Alarms. My User's Manual is in Japanese, and I only read and speak English, so I cannot post the User's Guide.
Sep 25, 2010 | Casio SL910LA Calculator
Iluv iMM153 please describe how I change the time from 24 hour
i have the exact same problem, i the picture of the product, it says pm on the side of the display, and its can say pm ont he display !!
Dec 11, 2009 | Audio Players & Recorders
York timer roblem
Grasp the timer dial with your fingers and pull out on it to turn. Set the time of day with arrow at bottom and release. That's it!
Jun 15, 2009 | York / Cam-stat Compressor Cycle Timer...
Clock & Date
You can download the manual from the link below: http://www.sharpusa.com/files/cal_man_EL1197PIII.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Sharp EL-1197P Calculator
Hardware & Accessories Logo
358 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
