Question about Eizo RadiForce R22 (Black) 21.3" LCD Monitor
Vertical Hum bars and Ghosting on monitors, How can I resolve this
Toshiba 40xv640u vertical ghosting
This will require a technician to resolve with some specially equipment.
May 14, 2012 | Computers & Internet
Blue vertical bar Left side and yellow,red vertical bars are seen both side of screen cause images are not readable
Hello
If the monitor displays these vertical bars, after a service has been done to it, and if LOT has replaced, there is a mismatching problem with replaced LOT and the defelction yoke.
Dec 18, 2011 | LG Studioworks 700S 17" CRT Monitor
Thin vertical colour bars from top to bottom across full width of screen
Welcome to FixYa,
Below are the top reasons why there are "colour bars" running across the screen :
  1. Corrupted video driver
  2. Changes in hardware configuration (display)
  3. Monitor issue (hardware)
In order to determine if it's hardware/software issue, all you need to do is to boot to BIOS and check if the problem replicates. Depending on system, you can go to the BIOS screen by tapping "F2" or "DEL" key repeatedly as soon as you turn on the computer until you see a different screen.
If the problem is present while in BIOS, then definitely the monitor needs to be repaired by an authorized repair center. Otherwise, video driver update or Operating system re-install can resolve this problem.
Hope this helps,
Thank you for using FixYa.
Jul 26, 2010 | HP Vs17 17" LCD Flat Panel Monitor
I am getting vertical bars moving up on my screen
vertical bars in video can be caused of poor filtering of voltage on the power supply,you need to open the back of the tv to repair the power supply.replace all bulging capacitor this causes the problem.Tnx
hope this help.
please rate my help.
Jun 05, 2010 | ViewSonic VA1912wb 19" LCD Monitor
3 shaded vertical bars on monitor about 3 inches
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
http://s807.photobucket.com/home/budm/allalbums
Apr 24, 2010 | ViewSonic VX1932wm Monitor
Wide horizontal bars ghosting across screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty its usually 3 years
Apr 12, 2010 | Acer AL1916W 19" LCD Monitor
Vertical lines and bad ghosting & image doubling
The Nvidea board is going bad - you proved that by using the old one.
Feb 10, 2010 | HP NVIDIA Quadro4 750 XGL (128 MB) AGP...
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
SyncMaster 920n Monitor 1 1/2" greeen colour vertical bar
Samsung products does not require u to produce a bill during warranty, ur product info will be registered in the database of the customer care center. So you can go in and get ur claim with the warranty. And the about the green lines, it could be that something is wrong with your graphics adapter.
Oct 12, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Eizo RadiForce R22 (Black) 21.3" LCD Monitor Logo
73 people viewed this question
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ShadeTek
ShadeTek
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
