Question about Vtech Kidizoom Digital Camera
The camera turns off as soon as you power it up
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Vtech service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 02, 2010
Why won't it start?
Here are a couple of things you can try:
Turn the lens clockwise then push the power button. As soon as you hear a click when you turn it push the power button and it should power up. Or
1. Push the power button.
2. double-tap the play-button at the bottom and the screen should activate. If so, push the menu-button. Go to settings and choose reset.
mendmy com How can fix my samsung camera help plz Cameras Film Cameras...
You may find this thread interesting, and helpful...
Oct 02, 2015 | Samsung ES90 Digital Camera
My camera turns off by itself as soon as I turn the power on.Even when its plug into the computer
Some parts of the circuit overheated due to moisture. Always keep batteries out of camera, and close it from humidity with a ziplock bag. Now you have to try to dry it off in a dry place(put a fan on the camera), and hope for the best.
Feb 15, 2012 | General Electric W1200 Digital Camera
As soon as i turn it on it beeps and says turn the power off and on again the lens wont move in and out
I'm sorry that the camera display the eror: turn the power off and on again. If turning the power on and off again does not resolve the error message, try doing a power reset. Refer the URL for the information to reset a Cyber-shot® digital still camera back to original factory settings:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C265373
If the issue is still unresolved, service may be required.
Jan 04, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
SONY CYBER SHOT MODEL DSC W-180. TURN THE POWER POWER OFF AND ON AGAIN MSG DISPLAYED AS SOON AS THE CAMERA ON IN STILL & VIDEO MODE. WANT SOLUTION
The message appears when the Camera is having some Internal malfunction. If the message re appear after turning off and on, try power resetting the Camera.
Performing a manual power reset
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from MENU>>SETTINGS>>INITIALIZE>>OK. Reset the camera to factory default to check if the issue can be resolved.
If the issue is still unresolved, service will be required.
Thanks,
KenSolutions
FixYa
Oct 30, 2010 | Cameras
Have a Vivicam 5022 - it keeps shutting off as soon as it is turned on. has fresh batteries and the membory card is empty. how do i fix?
1st, are you using high powered batteries? (NiMH), if so have you tried powering it up via mains power to see if its an issue with the batteries or the camera in general.
Nov 22, 2009 | Vivitar ViviCam 35 Digital Camera
Camera problem..
umm well i would think it is doing that just to save the battery so lik wen u turn it on then i would use it as soon as u turn it on if not it probley thinks ur not going to use it so lik i said turn it on and use it as soon as u turn it on......... hope this helps
Aug 13, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Camera comes on then turns right back off
use NIMH batt. NIMH gives you 1.2 power good for camera
ALCALINE & NICD gives 1.5 v which is bad and will discharge soon.
so use NIMH 2500 / 3200
Jun 18, 2009 | Sanyo VPC-S880 Digital Camera
Will not turn on
take the battery out for a few mins, press and hold power button, re-insert battery, worked for me????
Oct 07, 2008 | Jazz DV-179 Digital Camera
Powers off
I have the same problem. Removing the memory card and then starting up seemed to fix it; the camera would then start up ok even with the card in.
Nov 24, 2007 | Kodak EasyShare Z700 Digital Camera
Vtech Kidizoom Digital Camera Logo
118 people viewed this question
Top Vtech Cameras Experts
Tony
brian soufane
Are you a Vtech Camera Expert? Answer questions, earn points and help others
