Question about Car Audio & Video
AM/FM radio on boat,
Loud pops make radio unuseable. Was told that this was second radio installed in this boat that had same problem. A friend also has same problem. Is there a difference in Marine and automobile radios? Does the electrical system need a filter? It is just a boat battery 12 volt connection.
Any help would be appreciated.
  • 1 more comment
  • patrick65 May 28, 2008
    Different battery made no difference. Believe radio is already "broke", from some other source/incident. I found the place where this radio was sold and serviced. I will contact them for addtional help. Thanks. I will update this incident if I find a fix for this problem.
  • patrick65 May 29, 2008
    I did disconnect the radio from the boat battery, and hot wired a different battery to the radio. No change, radio still pops.
    This is a plane and simple circuit. Problem has to be in the radio itself, but I don't know what is causing it.
  • patrick65 Jun 08, 2008
    I went to a junk yard and purchased a car radio for $10. Grafted the plugs together and Walla! It worked. So problem was in the radio.
    Thanks for your thoughts.
I didn't mean replace the battery.
"I would bring another battery on board (Charged fully), one that isnt connected to the boats electrical system and see if the emi still afflicts reception."
NOT connected to the alternator.
Does the unit work fine in a car or at home?
Posted on May 29, 2008
  • 38 Answers
First thing i'd do here would be to investigate if the electromagnetic interference is coming in through the supply feed. I would bring another battery on board (Charged fully), one that isnt connected to the boats electrical system and see if the emi still afflicts reception. If it stops or reduces to a permissible level one can attack the problem with emi suppressors and filters. A good place to start would be the alternator, try suppressing the emi at source.
The second path the emi takes to pollute reception would be via air straight to the units antenna.
The solution sought here might not be a single remedy but a total of 3 or 4 tweaks, each leading to a percentage improvement. try shifting the antenna too, maybe shielding might contribute some.
Posted on May 27, 2008
  • Jango Fixit
    Jango Fixit Jun 08, 2008
    Sorry i misunderstood, the radio itself is busted right? I guess your next purchase ought to be a marine radio like u said.
Manual for WS-A8 mini portable music loud speaker with fm radio
pretty simple, turn it on for radio, hold mode utton for 2-3 seconds to switch to speaker mode. if u turn it off and turn it again on, it will always start in a radio mode! thats all
Jun 16, 2013 | WS-A8 Mini Portable Music...
XMD3 I bought a second hand boat with this radio , not working , do you have an installation schema ?Thanks
hello there ,firstly at the rear of the radio you will see two plastic blocks top block is your power in )secondly bottom block is your( audio ) sound these wires are colour coded for front and rear speakers ,your dc power which cannot be over 13.8v black and red wire on top block you have a socket to the right this will be for the antenna ,also check the fuse line before switching on hope this helps you
Mar 25, 2011 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
My three-year-old Model One has started making very loud popping/cracking noises intermittently on the FM band. It can work fine for several minutes, even half an hour or so, but invariably the noises...
I found in some cases that the tuning capacitor collects small particles of dust causing snaps, pops, and drop outs. One solution is get some electronic cleaning spray from radio shack or service shop. now open the back of the radio, look for square plastic box it is transparent and you will see metal plates with small screws. On the top you will see small round holes in the plastic, attach the supplied straw and spray inside two good blasts should do it. rotate the tuning several times back and forth this cleans the plates, until spray dries the station will be on wrong frequency until dries
Jan 07, 2011 | Tivoli Model One
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
Bose Wave Radio pops, loud hum that fades
Power supply capacitors have dried out and need to be replaced.
Sep 03, 2017 | Bose Wave Radio
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Back speakers won't work
Poor/old wires or blown out speakers...;)
Volume, Display and FM stations missing?
This could be a bad ground on the radio, or you have serious circuit problems. if a fuse blew, the radio would not work at all. Check the installation first, replace the radio seconds. Good Luck
Jul 29, 2007 | Sony CDX-L420V CD Player
Car Audio & Video Logo
435 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
