Question about Garmin nuvi 205W GPS Receiver
My Garmin Has No Voice Command. - Garmin nuvi 205W GPS Receiver
  • Garmin Master
  • 587 Answers
Tools... Settings...Language.... under Voice select one that has an ending with ( TTS ) text to speech
Posted on Nov 06, 2010
Lost voice command when i did update on my garmin
check settings or may need to redo the update.
Aug 19, 2014 | Garmin nuvi GPS
No voice command
Try going to the settings menu and look for voice options. Usually there is a box that needs to be checked for the option to work.
Apr 13, 2014 | Garmin nuvi 2555LMT
When i try to use the voice command on my garmin 3790 ltm it says that the feature is not available in Canada! It worked when i first bought it a month ago any way to reset it or any advice...thanks...
Hello and Welcome to FixYa! The voice command in Garmin 3790 totally depends on the mapset. Some custom mapsets lose this feature. It's to do with files used and converting files. Reverse converter often has this problem. It can also be caused by some unlocking techniques, May be you are somewhere in Canada where map set is not configured for this so your voice command is not working and you are getting this problem. You can call Garmin Support back to clarify this.
Though i am telling you that how can you Master reset it, May be it can helpful for you. First of all go to Map Screen, Press and hold speed icon, In trip calculator window, Hold the center dash icon until it takes you to config screen,here you can reset it
I hope I have given you a clear picture. If you have anything else in your mind to ask. Its you right. Do post.
Concerned, Nooh : Team FixYa
Sep 19, 2011 | GPS
How to activate voice command 3760t
Page 19 of your manual:
Activating Voice Command
Speak your wakeup phrase. The Voice Command menu appears.
Setting your Wakeup Phrase
The wakeup phrase is a word or phrase you can say to activate voice command. The default wakeup phrase is "Voice Command".
1. From main menu, touch Tools > Voice Command > Customize Phrase.
2. Enter a new wakeup phrase.
3. Touch "Done"
If this solves your posted problem, please come back and rate our answer. Thankyou.
Nov 05, 2010 | Garmin GPS
I have a garmin 3970t and the voice command does not work
The Garmin's not very good at recognising the default set phrase to initial voice command; i.e. "Voice Command". If you bring up the Tools menu, and touch Voice Command, it will tell you what phrase it's expecting to hear and provide a button to touch to customise it. The default, as I said, is "voice command", but for some reason, it thinks it's pronounced something like "Vwuss commont". Try it. It might work!
I changed my voice command phrase to "Voys Commarnd" (I'm English - it's how my accent would be written phonetically). It now works most of the time without a problem.
Aug 12, 2010 | Garmin GPS
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
I have no voice commnd
There is a software bug Garmin has been working on for a while. The voice file changes to none. To fix go to tools, settings voice and change to desired language. Sometimes the language files get messed uo and need reloaded from webudater, this can be obtained from www.garmin.com. The latest Garmin Software version is 4.80
Aug 29, 2009 | GPS
Garmin voice command not working
I am not fimiarly with tom tom, but I do know on my garmin gps, there is a mute feature on the volume. On my mine it is on the main menu screen right after you turn it on. On yours you may have to go to a menu or something to turn the mute off.
Aug 10, 2009 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
98 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
