Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
My refrigerator stopped running this morning. There is a lot of ice on the back wall of the freezer. The manual reads that the refrigerator will turn itself off while defrosting. Could this be the problem.
  • LG Master
  • 43,501 Answers
No, this is not the problem... the defrost is not working in your case...it may have hurt the compressor...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
How do I defrost my frozen freezer?
the defrost circuitry is not defrosting the unit due to a defectice defrost heater,thermostat or adc control,shut it off and let it defrost manually or use a hand held hair dryer to assist in the manual defrost,then remove the inside back wall cover in the freezer in there you will find the defrost heater and thermostat,have towels handy as when you manually defrost it you will have a lot of drainage and the catch pan in the back that catches this water will most likely overflow
Jan 31, 2013 | Maytag MBB2256G Bottom Freezer...
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Jun 10, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Refrigerator is not cold,freezer is frosting up
Defrost system failure is correct. It could be the evaporator fan, timer, heater. You can manually defrost with a hair dryer which will give you a couple of days until a service tech can determine which part has failed. Remember, there is a lot of ice behind the freezer back wall around the cooling coils. You can only see the tip of the iceburg.
Jan 22, 2009 | Kenmore Refrigerators
Refergirator not cooling
Defrost system failure.
Defrost system: Freezer fan, Defrost timer, Heater, Thermostat. If any one of these are bad the coils in the freezer will get clogged with ice and not allow the cold air to circulate over to the ref. side.
Ice/frost build up on the back wall of the freezer is an indication of this problem. You can manually defrost with a hair dryer which will give you a couple of days before it starts iceing up again. Remember, the ice you see on the back wall is just the tip of the iceburg, there is a lot more on the coils behind that wall.
Jan 06, 2009 | Amana ARS2464B Side by Side Refrigerator
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Warm fridge, cold freezer
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Oct 24, 2007 | Maytag MFD2560HES Bottom Freezer French...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
95 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
