I have a Casio EFA-120D. the minutes hand stuck at a position and stop moving. at H-S mode, i try to adjust the time the hand keep jumping but don't move forward.
thank you for your help.
Check if the battery is still in good condition. If this doesn't solve the problem, swipe a magnet over the back of the watch in different directions until the minute hand moves. Take care not to scratch the watch with the magnet. It may be necessary to oscillate the magnet several times at the correct position and direction until the minute hand moves freely.
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
A --- B Setting the digital time.
C __ D
Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Set time, Date, etc:
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
See: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf and go to the section "Adjusting the Home Position"
This is a "calibration" procedure to get the motor of the analog movement back to the home position of 12:00. This worked for me, after replacing the battery.
Note that in this procedure the hour hand does not move separately, but moves with the minute hand. So to get the hour hand to move, you have to let the minute hand spin a number of times until you get the hour hand up to twelve o'clock.
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
if you pull the crown out to the #2 position,then push the start/stop pusheryou will move the sweep sec. hand up to the 12 o'clock position. push in crown.
Don
