Question about Husqvarna 28cc Gas Line Trimmer
Had broken gas line, fixed it and now want crank, put new plug in
    President:
  • Husqvarna Master
  • 1,545 Answers
Check fuel flow to the engine. Make sure fuel line to the carb has fuel filter on the in-tank end and that it is clear. Make sure there is spark at the plug. Make sure your air filter is clean. Make sure the bolts to the engine cylinder and the lower crankcase cover are good and tight. If all the above check out OK, then you may need to remove the carb and clean it. Possible small fuel line particles entered the carb after it broke so the carb may need to be partially disassembled and cleaned. Post back as needed.
Posted on Oct 03, 2010
Atv not getti g gas to bowl, new carb petcock lines new gas ?
With the pet **** hooked up and in the open position from tank and vacuum line attached to carburetor and fuel line detached from intake of carb and in clear bottle crank engine. Does fuel go in bottle while cranking. Pour a few drops of fuel into in sparkplug hole reinsert the plug and plug wire to plug hook fuel line back to tank and carb turn on ignition and crank in neutral of course.
Oct 11, 2017 | GAS Motorcycles
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Tractor want crank after changing oil. is there a reset for this?
not that I am aware of,.try removing plug and try cranking it over see if it spewes out gas if so crank a bit and put plug in . it could run but the carb float has a problem .I usually add a gas line shutoff valve in the line to carb
May 10, 2015 | Garden
1977 jeep cj7 will not start very well and when it does it turns over a little and then shuts down any answers ?? the fuel pump seems to be ok.
If I remember correctly that Jeep had a mechanical fuel pump attached to the engine. I suggest you disconnect the fuel line before the fuel filter and put a pressure gauge on the line. Crank the engine for at least 15 seconds and go see if you have at least 7 lbs of pressure. If not, you need a new pump. It that was good, now disconnect the line AFTER the fuel filter and see if you have a sufficient volume of fuel coming out. For that I suggest you have someone else crank the engine while you hold the hose in a pail. If the stream is weak, change the filter, reconnect the line and see what happens. If it still starts and stalls it could be a clogged carburetor.
Did you do a spark check by holding the plug wire away from the engine while someone cranks it? With a spark plug in the wire, hold it at least 1/2 inch from the engine while someone cranks it. That spark should be able to jump off the plug and into the engine. If not, you have a weak coil. If the spark is strong and you have the correct plugs installed, then it almost has to be the carburetor.
Good luck with that, I have fond memories of older jeeps.
Feb 03, 2015 | Jeep CJ7 Cars & Trucks
Scag tiger cat wont start
I would put new plugs in change the oil put a new in line gas filter in. After this tune-up check for spark by leaving the plug out on the moter body crank it over if the spark is hot you know its a gas problem also check for any grounding by starting it at night then looking around to the engine to see if its grounding out. Try these simple things. Do not change anything on the moter without doing these things first. Good luck
Apr 11, 2014 | Scag Tiger Cat 52 Zero Turn Mower...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
2000 fatboy will start but wont stay running, have replaced the map sensor, crank sensor, cam sensor. Put a new ignition module and a new coil. Sounds great when it starts but wont stay running. Have
Hi Manda, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 28, 2012 | Harley Davidson FLSTF Fat boy Motorcycles
Having trouble runing and cranking will crank sometimes when give it gas put in gear it dies new sparkpluggs fouled out smell oil when dies
PROBLEM COULD BE IGNITION MODULE OR BAD COILS.CHECK FUEL PRESSURE REGULATOR.MAKE SURE ITS GETTING VACUUM.AT THE VACUUM DIAPHRAM.IF NOT LOOK FOR BROKEN OR DISCONNECTED VACUUM LINES ON THE VALVE COVER INTAKE MANIFOLD. LOOK FOR SIGNS OF GASOLINE IN THE VACUUM LINE OR FUEL PRESSURE REGULATOR VACUUM DIAPHRAM.IF SO FUEL PRESSURE REGULATOR NEED REPLACING.
Jun 13, 2011 | 1999 Saturn SL
I've put a new sparkplug and new filter -but the blower won't start . Doesn't even feel like it wants to start
Put a spoon full of gasoline straight down the plug hole. Reinstall the plug, if it starts then you obviously have a fuel problem. You may need a new kit installed in the carburetor. Easy fix.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
Husqvarna 28cc Gas Line Trimmer Logo
55 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
